Inleiding
This guide requires basic disassembly skills to get inside the phone. Allowing you to pull out and then realign the buttons.
Wat je nodig hebt
Using a Phillips #1 screwdriver, remove the 4.8mm screw on the battery cover by twisting the screwdriver counter-clockwise.
Remove 4 13.8mm screws holding the device back using a Phillips #1 screw driver.
Één andere persoon heeft deze handleiding voltooid.
