Ga door naar hoofdinhoud
Philips TAS7505 Outer Shell Disassembly
Wat je nodig hebt
  1. Philips TAS7505 Outer Shell Disassembly, Philips TAS7505 Outer Shell Disassembly: stap 1, afbeelding 1 van 2 Philips TAS7505 Outer Shell Disassembly, Philips TAS7505 Outer Shell Disassembly: stap 1, afbeelding 2 van 2
    • Make sure the speaker is turned off before you begin the disassembly.
    • Turn the speaker upside down. You will see a rubber base. Use an opening tool to lift up the sides to expose the screws.
  2. Philips TAS7505 Outer Shell Disassembly: stap 2, afbeelding 1 van 3 Philips TAS7505 Outer Shell Disassembly: stap 2, afbeelding 2 van 3 Philips TAS7505 Outer Shell Disassembly: stap 2, afbeelding 3 van 3
    • There will be 4 exposed screws. Make sure to use the Phillips #0 Screwdriver.
    • When the screws are removed, you can use an opening tool to take off the plastic cover.
  3. Philips TAS7505 Outer Shell Disassembly: stap 3, afbeelding 1 van 3 Philips TAS7505 Outer Shell Disassembly: stap 3, afbeelding 2 van 3 Philips TAS7505 Outer Shell Disassembly: stap 3, afbeelding 3 van 3
    • Now that you have removed this cover, there is another cover. This cover has a total of 9 screws that can be removed with a Philips #0 screwdriver.
    • Once all these screws are removed, you can take off the cover
  4. Philips TAS7505 Outer Shell Disassembly: stap 4, afbeelding 1 van 3 Philips TAS7505 Outer Shell Disassembly: stap 4, afbeelding 2 van 3 Philips TAS7505 Outer Shell Disassembly: stap 4, afbeelding 3 van 3
    • You can now see the inside of the speaker but you aren't done yet.
    • Remove both rubber stands that hold up the device horizontally (one of these stands is a cover for the USB ports).
  5. Philips TAS7505 Outer Shell Disassembly: stap 5, afbeelding 1 van 1
    • Once you pull these out, you can pull the whole sleeve to expose the infrastructure of the device.
Conclusie
Joseph Hernandez
171 Reputatie
1 Handleiding geschreven
CSU Los Angeles, Team 5-2, Adachi Fall 2022 Lid van CSU Los Angeles, Team 5-2, Adachi Fall 2022
CSULA-ADACHI-F22S5G2
5 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 146
