Ga door naar hoofdinhoud
Philips TAS7505 Motherboard Replacement
Wat je nodig hebt
  1. Philips TAS7505 Motherboard Replacement, Philips TAS7505 Outer Shell Disassembly: stap 1, afbeelding 1 van 2 Philips TAS7505 Motherboard Replacement, Philips TAS7505 Outer Shell Disassembly: stap 1, afbeelding 2 van 2
    • Make sure the speaker is turned off before you begin the disassembly.
    • Turn the speaker upside down. You will see a rubber base. Use an opening tool to lift up the sides to expose the screws.
  2. Philips TAS7505 Motherboard Replacement: stap 2, afbeelding 1 van 3 Philips TAS7505 Motherboard Replacement: stap 2, afbeelding 2 van 3 Philips TAS7505 Motherboard Replacement: stap 2, afbeelding 3 van 3
    • There will be 4 exposed screws. Make sure to use the Phillips #0 Screwdriver.
    • When the screws are removed, you can use an opening tool to take off the plastic cover.
  3. Philips TAS7505 Motherboard Replacement: stap 3, afbeelding 1 van 3 Philips TAS7505 Motherboard Replacement: stap 3, afbeelding 2 van 3 Philips TAS7505 Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Now that you have removed this cover, there is another cover. This cover has a total of 9 screws that can be removed with a Philips #0 screwdriver.
    • Once all these screws are removed, you can take off the cover
  4. Philips TAS7505 Motherboard Replacement: stap 4, afbeelding 1 van 3 Philips TAS7505 Motherboard Replacement: stap 4, afbeelding 2 van 3 Philips TAS7505 Motherboard Replacement: stap 4, afbeelding 3 van 3
    • You can now see the inside of the speaker but you aren't done yet.
    • Remove both rubber stands that hold up the device horizontally (one of these stands is a cover for the USB ports).
  5. Philips TAS7505 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Once you pull these out, you can pull the whole sleeve to expose the infrastructure of the device.
  6. Philips TAS7505 Motherboard Replacement, Motherboard: stap 6, afbeelding 1 van 3 Philips TAS7505 Motherboard Replacement, Motherboard: stap 6, afbeelding 2 van 3 Philips TAS7505 Motherboard Replacement, Motherboard: stap 6, afbeelding 3 van 3
    • Disconnect the battery from the motherboard by unclipping it from the side not visible to you
    • If you are having difficulties disconnecting the battery you can pull the battery out whole in order to get a better angle to disconnect it
  7. Philips TAS7505 Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Pull out the motherboard then disconnect the USB-A & USB-C port by pressing the clip
  8. Philips TAS7505 Motherboard Replacement: stap 8, afbeelding 1 van 2 Philips TAS7505 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Next is to disconnect the speaker
    • pull the motherboard out as much as you can and then wiggle the white box back and forth to get it out
  9. Philips TAS7505 Motherboard Replacement: stap 9, afbeelding 1 van 2 Philips TAS7505 Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Simply remove this white strand with a pair of tweezers.
  10. Philips TAS7505 Motherboard Replacement: stap 10, afbeelding 1 van 2 Philips TAS7505 Motherboard Replacement: stap 10, afbeelding 2 van 2
    • This is how the motherboard should be after doing all the steps correctly.
Conclusie
Alejandro
121 Reputatie
1 Handleiding geschreven
CSU Los Angeles, Team 5-2, Adachi Fall 2022 Lid van CSU Los Angeles, Team 5-2, Adachi Fall 2022
CSULA-ADACHI-F22S5G2
5 Leden
5 handleidingen geschreven
Één opmerking
The guides are very detailed with many steps and are easy to follow. It looks professional and well-made. Thank you for your contribution to Ifixit!
Dat Nguyen - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 116
