Ga door naar hoofdinhoud
Philips TAS7505 Battery Replacement
Wat je nodig hebt
  1. Philips TAS7505 Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Philips TAS7505 Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Philips TAS7505 Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Remove the rubber cover from the bottom of the speaker using your opening tool.
    • However, this will make it much harder to place the rubber cover back where it was and may not stick, but it is unnecessary for the speaker to function.
  2. Philips TAS7505 Battery Replacement: stap 2, afbeelding 1 van 3 Philips TAS7505 Battery Replacement: stap 2, afbeelding 2 van 3 Philips TAS7505 Battery Replacement: stap 2, afbeelding 3 van 3
    • Get your Philips 0 bit screwdriver and remove the 4 screws attached to the cover and then remove the cover with the opening tool that you used for the rubber cover.
  3. Philips TAS7505 Battery Replacement: stap 3, afbeelding 1 van 2 Philips TAS7505 Battery Replacement: stap 3, afbeelding 2 van 2
    • Remove all the screws using the same screwdriver to remove the final layers to open up the inside.
  4. Philips TAS7505 Battery Replacement: stap 4, afbeelding 1 van 2 Philips TAS7505 Battery Replacement: stap 4, afbeelding 2 van 2
    • After opening the Philips speaker, remove the battery from the motherboard.
    • The cable that connects the battery to the speaker is attached to small pins. You can use your hands to wiggle the battery out.
  5. Philips TAS7505 Battery Replacement: stap 5, afbeelding 1 van 2 Philips TAS7505 Battery Replacement: stap 5, afbeelding 2 van 2
    • After removing your battery. Get your replacement battery and place it in. Then Redo the steps form the bottom to the top.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Frederick Jimenez
277 Reputatie
2 handleidingen geschreven
CSU Los Angeles, Team 5-2, Adachi Fall 2022 Lid van CSU Los Angeles, Team 5-2, Adachi Fall 2022
CSULA-ADACHI-F22S5G2
5 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 31
Altijd: 216
