Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
The toughest part with this task is the separation of the outer shell and the inner workings. The two tabs that hold it together are hard to locate and separate. They do require a lot of force to actually get separated.
  1. Here is the Philips Sonicare handle HX9340 that no longer holds a charge This is the bottom endcap that requires removal. A few layers of cardboard gets wrapped around the handle to protect it from any marring or other damage.
    • Here is the Philips Sonicare handle HX9340 that no longer holds a charge
    • This is the bottom endcap that requires removal.
    • A few layers of cardboard gets wrapped around the handle to protect it from any marring or other damage.
    Die Endkappe lässt sich ohne Rohrzange relativ einfach mit dem Jimmy raushebeln.
    Martin Jaeger - Antwoord
    Wenn die Bürste nicht mehr reagiert und auch nicht lädt, muss nicht zwingend der Akku mürbe sein. Bei meiner HX9370 war die Kopfdichtung undicht. Dadurch kam Wasser ins Innere. Nach trockenblasen mit Pressluft lädt und arbeitet die Zahnbürste wieder. Meine Herausforderung ist jetzt noch, eine passende Kopfdichtung zu bekommen.
    • BEFORE trying with tools, it is possible to get the cap off as well as the inner part of the toothbrush without any tools. This will not damage the toothbrush; actually it will possibly save the toothbrush from being marred.
    • Simply push the metal head at the top of the tootbrush downwards into a hard surface with some force and the bottom cap and the inner part will pop out by itself.
    • This works on both old and new Sonicare models.
    • If this worked for you, simply skip Steps 3–6.
  2. Using a pair of pliers to apply some pressure round the handle. The best place to start is the wider part of the rectangular base and about 1/2" to 3/4" from the bottom Continue to apply pressures around the whole base of the the handle moving to each side of the rectangular base. It may take a few complete rotations to finally open up the gap between base and handle.
    • Using a pair of pliers to apply some pressure round the handle. The best place to start is the wider part of the rectangular base and about 1/2" to 3/4" from the bottom
    • Continue to apply pressures around the whole base of the the handle moving to each side of the rectangular base.
    • It may take a few complete rotations to finally open up the gap between base and handle.
  3. Once the gap opens up, utilize a small flathead screwdriver to insert it into the gap to widen it. Endcap coming out of the handle. Once the gasket will become completely visible the endcap can be removed.
    • Once the gap opens up, utilize a small flathead screwdriver to insert it into the gap to widen it.
    • Endcap coming out of the handle. Once the gasket will become completely visible
    • the endcap can be removed.
  4. Here is the endcap showing the tabs that hold it securely in place once inserted There will be two plastic tabs that hold the inner workings to the outside handle. These are hard to reach and not easy to see. Using a long small flathead screwdriver (or similar tool) to find those tabs is the difficult part on this job.
    • Here is the endcap showing the tabs that hold it securely in place once inserted
    • There will be two plastic tabs that hold the inner workings to the outside handle. These are hard to reach and not easy to see.
    • Using a long small flathead screwdriver (or similar tool) to find those tabs is the difficult part on this job.
  5. Once the tabs have been properly located, insert one tool on each side to loosen compress the base and apply downward pressure on the outer handle. For this the top end of the handle needs to rest against a solid base. It does require a considerable amount of downward force to accomplish this. With the tabs loosened and the handle opushed downward, the inner workings of the toothbrush will loosen and pop out of the handle. Remove the mechanics out of the handle.
    • Once the tabs have been properly located, insert one tool on each side to loosen compress the base and apply downward pressure on the outer handle. For this the top end of the handle needs to rest against a solid base. It does require a considerable amount of downward force to accomplish this.
    • With the tabs loosened and the handle opushed downward, the inner workings of the toothbrush will loosen and pop out of the handle.
    • Remove the mechanics out of the handle.
    I found I had to use two very thin (almost sharpened) flat screwdrivers to get between the taps and the outer handle. And then push down the outer handle. It's no use just pushing the inner base down.
    Geos Yannis - Antwoord
    I found I had to use two very thin (almost sharpened) flat screwdrivers to get between the taps and the outer handle, to push them towards the center (i.e. each other), so that they unlock from their recess in the outer handle. And then push down the outer handle to slide out the inner workings. It's no use just pushing the inner base down.
    Nachdem die Rasten etwas gelockert wurden, kann man mit der Rohrzange auch in deren Höhe kräftig & beherzt drücken (auf die schmale Seite) und dann die Bürste auf kräftig auf den Tisch schlagen (weiter gedrückt hatten) … dann kommt die Mechanik auch heraus
    Jürgen Laskowski - Antwoord
    Druck mit der Zange in Höhe der Rasten (ohne vorher irgendwas zu lockern) auf der schmalen Seite und gleichzeitig kräftiger Druck nach unten auf den Tisch hat bei mir auch gut funktioniert.
    Martin Niehoff - Antwoord
    Pheww that was hard. I used the smallest flat head bike tool I had, with flashlight in month, pried open one of the tabs then slid a thin piece of plastic in between (plastic slip cut from plastic cup); then, I proceeded with foing the same on the other side. Success.
    Simon Li - Antwoord
    That left tab looks kind of mangled. You can’t go straight down to remove the tabs you have to go behind them and twist the screwdrivers to disengage them. I used two small screwdrivers. Once you do that it actually requires very little force to push out of the body.
    Narek Bayanduryan - Antwoord
  6. Remove the rubber protectors from the PCB side as well as the battery. Here is the battery to be replaced. Sanyo part number 4235 010 13068
    • Remove the rubber protectors from the PCB side
    • as well as the battery.
    • Here is the battery to be replaced. Sanyo part number 4235 010 13068
  7. There are three places that will have to be desoldered. Positive battery contact Negative battery contact
    • There are three places that will have to be desoldered.
    • Positive battery contact
    • Negative battery contact
    • and a jumper
    • For the jumper the only thing required is to remove the solder between the pads.
    • Apply some flux to the jumper. The pliers will help to stabilize the PCB during soldering. any other means to hold it steady can be used.
    Why do we need to desolder the jumper?
    Ben Williams - Antwoord
  8. Using a soldering iron, remove the solder bridge between the jumper pads. Using flux and desoldering braid remove the solder from the negative tab of the battery. Solder bridge from jumper cleaned
    • Using a soldering iron, remove the solder bridge between the jumper pads.
    • Using flux and desoldering braid remove the solder from the negative tab of the battery.
    • Solder bridge from jumper cleaned
    • Negative battery tab unsoldered from PCB
  9. Apply flux to the positive contact of the battery on the PCB (Incidental finding is a SMD fuse F1 on this PCB) Using desoldering braid unsolder the positive contact from the PCB. Apply some gentle pressure with a small tool to remove the battery.
    • Apply flux to the positive contact of the battery on the PCB (Incidental finding is a SMD fuse F1 on this PCB)
    • Using desoldering braid unsolder the positive contact from the PCB.
    • Apply some gentle pressure with a small tool to remove the battery.
    • The battery should remove easily. If it does not, double check the battery contacts on the PCB to ensure they are not still connected somewhere. Another going over with the soldering iron may be required to complete that task.
  10. Battery removed from the PCB and the solder pads on the PCB are now clearly visible In an attempt to determine the type off battery the red plastic covering was removed.  The battery is a 3.7V lithium-ion battery that measures approximately (rounded) 14mmX49mm. Roughly the size of a AA battery. The groove on the battery is always on the positive end of the battery.
    • Battery removed from the PCB and the solder pads on the PCB are now clearly visible
    • In an attempt to determine the type off battery the red plastic covering was removed. The battery is a 3.7V lithium-ion battery that measures approximately (rounded) 14mmX49mm. Roughly the size of a AA battery.
    • The groove on the battery is always on the positive end of the battery.
    The battery is a “14500” Li ion battery. You can find them easily. You can buy them with tabs, or without tabs.
    Geobio Boo - Antwoord
Conclusie
31 andere personen hebben deze handleiding voltooid.
oldturkey03
671.920 Reputatie
103 handleidingen geschreven
This has helped me a lot and i used it as a base for my fixit tutorial. Thank you!
moritz - Antwoord
Hallo moritz, bitte tausche in deiner Anleitung die Sprache in Englisch da jetzt die Deutsche Anleitung in Englisch geschrieben ist.
Claes -
Nach dem wechsel der Batterie leuchten alle Lampen, aber die Bürste gibt keine Vibrationen ab. Wo ist der fehler? Hatte jemand dieses Problem?
After replacement of the akku all lamps are flashing but there is no function of the vibration-module. anyone knows this problem?
matze - Antwoord
Das wird wahrscheinlich daran liegen, dass zwischen der Antriebseinheit und der BürstenWelle kein Platz ist. Sprich der Magnet liegt auf der Antriebseinheit an. Um das Problem zu lösen musst du zwei feststellschrauben lösen, den Spalt herstellen und dann die feststellschrauben wieder anziehen. Dann sollte die BürstenAufnahme wieder schwingen.
Kilian Müller -
Thanks for information. This guide leads to success. *Thumbs up* My Sonicare is back at work now. :-)
Stephan Müller - Antwoord
Really useful.
Geordi La Forge - Antwoord
It’s very helpful, I like it very much!!!
I just curious why the jumper have to be desoldered, is this jumper will limit the charge counter?
Thacker - Antwoord
Great guide, just needed to find out how to open the unit. Found that my problem was a loose screw failing to hold the metal mounting post for the brush head. Had contacted Philips who declined to help with repair but offered a 20% discount code for me to buy from their site. On there site I found my 2.5yr old Philips Sonicare DiamondClean Electric Toothbrush selling for £299.00 before discount and postage! Thanks Philips for trying to get a good portion of my pension this month. Thanks to ifixit and the writer of this guide for helping me not leave that much of my pension with Philips.Great to be able to take control of the situation and repair my own equipment!!!!
Jim dunne - Antwoord
@ifixitjdunne1 Hey Jim, you are welcome. Glad we could help you save some money. :-)
oldturkey03 -
You have to resolder the jumper when done else it doesn’t work, I presume its a safety thing because you are working with a live battery and a metal tipped soldering iron. I would recommend looking at the other guide for magnet adjustment on here and carrying that out when the battery is removed, I expect most will need this done after some use the coil and magnet move closer together, toothbrush gets noisy and weaker. for reference my battery was a sony one not sanyo. the part number 4235 010 13068. They are 14500 battery with tabs for PCB mount. the specific ones sold on ebay are expensive and possibly fake. I just got a pack of 4 soshine 14500 900mAh and soldered wires on to attach to the pcb
Scott Pattinson - Antwoord
you have to resolder the jumper, it is required. this must be a saftey thing to isolate battery from pcb while you work on it. recommend that magnet adjustment is done while you have it apart. I used soshine 14500 900mAh battery and soldered some wires to it for pcb attach. I didn’t truest the probably fake specific batteries on ebay that are being sold at inflated prices. The battery I removed was a sony one not sanyo as being sold on ebay. p/n 4235 010 13068
The “jumper” solder points need to be bridged again for it to work
my toothbrush had a sony battery in it and was about 5 years old when I replaced it. Some of the replacements available on popular sites are not sony. I opted to buy a good brand 14500 battery without the tabs and just solder my own wires to it.
While you have it apart I recommend that the other ifixit guide is followed to get the correct distance between the coil and magnet for best performance
I attempted this today but my toothbrush still won’t turn on. The new battery tests as working with a multimeter, and the old one is definitely dead. Before I start poking for other failure points, are there other test points I can use to ensure my soldering job is working?
Also, why unsolder the jumper if it just needs to be bridged again?
rsbrogna - Antwoord
rsbrogna I believe the jumper had to do with the counter plus it was easier for me to do it that way. The only point I can think of where to test is at the fuse on the PCB.
oldturkey03 -
I tried to re-aligned the magnetic motor and when I reassembled the toothbrush there was no power at all. I think it’s because somehow the fuse on the PCB has gone, as if I make a connection across the fuse on the PCB power can return. Is there any way of replacing the fuse so I can get it working again? Thanks
Dan Solomon - Antwoord
@solly90
Fuse= (watts/volts)X1.25
Watt = Amps x Volt
Watt = .9 X3.7
Watt = 3.3
Fuse = (3.3/3.7)x1.25
Fuse = 1.125
~1.5 Amp fuse will work. Measure the width and length of your fuse to determine the package size and check on places like Mouser or Digikey for a replacement
oldturkey03 -
Has anyone found a source for the small rubber o-ring that is on the outside under the plastic toothbrush for a model HX9340? Mine disentigrated and I do not know size or type.
gww - Antwoord
Who’d’ve thunk a toothbrush had so much in it. Is that a microprocessor and a serial comms port I see??
Got mine apart in no time at all. Checked the battery voltage (3.8V so that’s OK). The mode LEDs all light up, but the on switch doesn’t turn it on. It was quite wet inside though, probably damaged some of the delicate electronic wizardry. Not a great O-ring seal.
Thanks to ifixit for prompting me and helping me to have a go though.
Nick Arran - Antwoord
Hi. Just removed mine. Some comments:
Step 3: No need to use a screwdriver to pry out the end cap. Slowly pressuing the handle, while rotating around, it will work itself out. This is better to avoid damaging the end cap and o-ring (as seen in the pics step 5).
Step 6: I just tapped the bottom on the table and it fell down. No need to press inside sides and push end.
Rgds
Happy Guy - Antwoord
I did replace the battery, placed in the charger and It started blinking green light. In the morning toothbrush was charged but after assembling back I pressed a button and It worked for 3 seconds two times and now it’s again not responding. What may be the reason?!
Sanyo battery replaced with Sony as given in electronic store as a spare battery for HX9340.
Dariusz Sierzputowski - Antwoord
Vielen Dank für die tolle Anleitung. Meine Zahnbürste funktioniert wieder tadellos.
tanjataller - Antwoord
Ich konnte den Akku meine Sonicare dank der Anleitung erfolgreich wechseln. Vielen Dank!
PS: Mich würde auch interessieren war um der Jumper entlötet und dann neu verlötet werden muss…
Steffen Engel - Antwoord
Damit wird der Akku abgeklemmt. Ist eine leicht durchzuführende Maßnahme.
Ginge vielleicht auch ohne, aber sicher ist sicher!
VauWeh -
Hallo,
habe meine Zahnbürste erfolgreich zerlegt, den Akku nachgemessen - ist voll mit 3,8 Volt. Sobald ich den Anschalter betätige, zuckt der Magnet nur mal ganz kurz und man sieht ein sehr kurzes Aufflackern einer LED (auf der Platine neben CR2). Die Zahnbürste verweigert aber nach wie vor den Betrieb. Was kann das sein?
Stefan
Stefan Köhl - Antwoord
Bei mir das gleiche Problem. Hab auch schon die andere Anleitung bezüglich Motor schwächelt probiert… Kein Erfolg.
Wahrscheinlich ist der interne Zähler von Philips abgelaufen, wie oft man Zahnbürste benutzen darf bis man eine neue kaufen muss :(
Chris O -
Nach dem Akkuwechsel funktionierte nichts mehr.
Die Sicherung F1 war durch.
Wenn ich sie überbrücke, ist alles O.K.
Andreas Schulz - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 53
Afgelopen 7 dagen: 454
Afgelopen 30 dagen: 1,784
Altijd: 67,807
