Ga door naar hoofdinhoud
Philips Saeco Poemia espresso machine thermostat and o-ring replacement
Wat je nodig hebt
  1. Philips Saeco Poemia espresso machine thermostat and o-ring replacement, Introduction: stap 1, afbeelding 1 van 1
  2. Philips Saeco Poemia espresso machine thermostat and o-ring replacement, Wiring diagram: stap 2, afbeelding 1 van 1
  3. Philips Saeco Poemia espresso machine thermostat and o-ring replacement, Thermostats: stap 3, afbeelding 1 van 1
    • After disassembling the machine, it's easy to find the thermostats. They are attached to the top of the boiler with clips. There are two thermostats:
    • 95 ° C - brewing temperature (just below the boiling point of water)
    • 127 ° C - steaming temperature (just below the boiling point of water)
    • You can test the thermostats with a multimeter set to the resistance (ohms) setting. These thermostats are "normally-closed" which means at room temperature, the thermostat switch is closed. The meter should show close to 0 ohms when connected to the thermostat terminals.
    • You can remove the thermostats and check to see that they open when their temperature setting is reached. Carefully use a heatgun and an infrared thermometer to heat the thermostat above their set point. If you overheat them, you will melt the plastic case and destroy them. (Not that I did anything like that.... :-) )
  4. Philips Saeco Poemia espresso machine thermostat and o-ring replacement: stap 4, afbeelding 1 van 1
  5. Philips Saeco Poemia espresso machine thermostat and o-ring replacement, Generic Thermostats: stap 5, afbeelding 1 van 1
  6. Philips Saeco Poemia espresso machine thermostat and o-ring replacement, Modify the generic thermostats: stap 6, afbeelding 1 van 1
    • The connectors on these generic thermostats need 2 modifications to work with the Saeco Poemia:
    • Cut/file the terminal width by about 1mm. I used a small file.
    • Bend the terminals at a right-angle to match the originals.
    • The mounting tabs are different than the original, but they work just fine under the spring clip.
  7. Philips Saeco Poemia espresso machine thermostat and o-ring replacement, Heat sink compound: stap 7, afbeelding 1 van 1
    • Be sure to put some heat sink compound between the thermostat and the top of the boiler to insure accurate temperature sensing. Any low-cost type will be fine.
  8. Philips Saeco Poemia espresso machine thermostat and o-ring replacement, Testing: stap 8, afbeelding 1 van 1
    • After I replaced the thermostats and tested the machine, I checked the temperature of the boiler with a multimeter and temperature probe. I put the temperature probe under the thermostat clip.
  9. Philips Saeco Poemia espresso machine thermostat and o-ring replacement: stap 9, afbeelding 1 van 1
    • While testing, I noticed water and steam coming out of the boiler around one of the heating element terminals. Uh oh... I took apart the boiler and replaced the silicone o-ring gaskets. The video was very helpful to disassemble and reassemble the boiler. Checked again - no leaks!
  10. Philips Saeco Poemia espresso machine thermostat and o-ring replacement: stap 10, afbeelding 1 van 1
Conclusie
Use generic thermostats to make this low-cost repair.
4 andere personen hebben deze handleiding voltooid.
Wayne Seltzer
1.732 Reputatie
10 handleidingen geschreven
Global Fixers Lid van Global Fixers
Community
45 Leden
702 handleidingen geschreven
Één opmerking
this is a great guide, hard to find stuff about this machine.
Sebastian Muller - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 36
Afgelopen 30 dagen: 118
Altijd: 7,460
