Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Inleiding
The speakers are the two circular objects inside the device. This guide will detail the steps in how to replace a damaged speaker.
  1. Remove the back cover by sliding it off.
    • Remove the back cover by sliding it off.
    • Remove the 3 AAA batteries.
  2. Unscrew the nine exterior screws on the back panel using a PH0-size Philips-head screwdriver. NOTE: A larger screwdriver head and more force may be required for damaged screws. Remove the triangular end piece by pulling it straight off.
    • Unscrew the nine exterior screws on the back panel using a PH0-size Philips-head screwdriver.
    • NOTE: A larger screwdriver head and more force may be required for damaged screws.
    • Remove the triangular end piece by pulling it straight off.
  3. Remove the colored grill by sliding it off in the direction of the removed end piece. Pry off the back battery panel with the plastic opening tool.
    • Remove the colored grill by sliding it off in the direction of the removed end piece.
    • Pry off the back battery panel with the plastic opening tool.
    • NOTE: Be careful to avoid tearing any wires.
  4. Remove the circuit board by unscrewing the two interior screws located on the circuit board. Pull out the battery plugs from the circuit board by pulling out the plugs to fully remove the back panel from the rest of the speaker.
    • Remove the circuit board by unscrewing the two interior screws located on the circuit board.
    • Pull out the battery plugs from the circuit board by pulling out the plugs to fully remove the back panel from the rest of the speaker.
  5. Locate the speaker needing replacing. Remove the one screw holding the speaker in place with a PH0 size philips head screw driver.
    • Locate the speaker needing replacing.
    • Remove the one screw holding the speaker in place with a PH0 size philips head screw driver.
  6. Score the glue that is holding the speaker in place with the spudger, and use your hands to pry off the speaker. Score the glue that is holding the speaker in place with the spudger, and use your hands to pry off the speaker. Score the glue that is holding the speaker in place with the spudger, and use your hands to pry off the speaker.
    • Score the glue that is holding the speaker in place with the spudger, and use your hands to pry off the speaker.
  7. Using a non-conductive glue, carefully seal the speaker to the casing. Follow the glue instructions as set by the manufacturers. Let the glue set the appropriate amount of time.
    • Using a non-conductive glue, carefully seal the speaker to the casing.
    • Follow the glue instructions as set by the manufacturers. Let the glue set the appropriate amount of time.
    • Reassemble the device
Conclusie
Één andere persoon heeft deze handleiding voltooid.
April Driscoll
321 Reputatie
3 handleidingen geschreven
Clemson, Team 14-4, Benson Fall 2013 Lid van Clemson, Team 14-4, Benson Fall 2013
CLEM-BENSON-F13S14G4
3 Leden
4 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 1,288
