Ga door naar hoofdinhoud
Philips SBA1060 Capacitor Replacement
Wat je nodig hebt
  1. Philips SBA1060 Capacitor Replacement, Battery Casing: stap 1, afbeelding 1 van 1
    • Remove the back cover by sliding it off.
    • Remove the 3 AAA batteries.
  2. Philips SBA1060 Capacitor Replacement: stap 2, afbeelding 1 van 3 Philips SBA1060 Capacitor Replacement: stap 2, afbeelding 2 van 3 Philips SBA1060 Capacitor Replacement: stap 2, afbeelding 3 van 3
    • Unscrew the nine exterior screws on the back panel using a PH0-size Philips-head screwdriver.
    • A larger screwdriver head and more force may be required for damaged screws.
    • Remove the triangular end piece by pulling it straight off.
  3. Philips SBA1060 Capacitor Replacement: stap 3, afbeelding 1 van 2 Philips SBA1060 Capacitor Replacement: stap 3, afbeelding 2 van 2
    • Remove the colored grill by sliding it off in the direction of the removed end piece.
    • Pry off the back battery panel with the plastic opening tool.
    • Be careful to avoid tearing any wires.
  4. Philips SBA1060 Capacitor Replacement, Capacitor: stap 4, afbeelding 1 van 1
    • Remove the two screws on opposite ends of the circuit board with the PH0 size philips head screw driver.
    • Slowly pull the circuit board out of the device
    • NOTE: Be careful not to damage any of the wires protruding from the back of the circuit board.
  5. Philips SBA1060 Capacitor Replacement: stap 5, afbeelding 1 van 2 Philips SBA1060 Capacitor Replacement: stap 5, afbeelding 2 van 2
    • Flip the device and remove the battery plug from the circuit board by pulling out the plugs to fully remove back panel.
    • Remove the speaker plugs from the circuit board by pulling out the plugs. They are located on opposite sides of the circuit board.
    • NOTE: When reassembling, note that the speaker with the red wire goes to the red plug, and the speaker with the white wire goes to the adjacent white plug.
    • Remove the light plug from the circuit board.
    • NOTE: This plug is twice as wide as the speaker and battery plugs.
  6. Philips SBA1060 Capacitor Replacement: stap 6, afbeelding 1 van 2 Philips SBA1060 Capacitor Replacement: stap 6, afbeelding 2 van 2
    • Locate the capacitor and carefully slide it out of the circuit board.
    • NOTE: The capacitor will be a cylindrical object protruding vertically near the center of the circuit board.
    • Slide the prongs of the replacement capacitor into the two holes of the circuit board where the original capacitor was removed from.
    • Reassemble the speaker.
Conclusie
April Driscoll
321 Reputatie
3 handleidingen geschreven
Clemson, Team 14-4, Benson Fall 2013 Lid van Clemson, Team 14-4, Benson Fall 2013
CLEM-BENSON-F13S14G4
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 5
Altijd: 731
