Ga door naar hoofdinhoud
Philips Respironics V200 Esprit Oxygen Valve Replacement
Medische apparatuur
Noch iFixit, noch deze reparatiehandleiding worden onderschreven door of zijn gelieerd aan de fabrikant van de desbetreffende medische apparatuur.
Wat je nodig hebt
  1. Philips Respironics V200 Esprit Oxygen Valve Replacement, Oxygen Valve: stap 1, afbeelding 1 van 1
    • Before replacing the oxygen valve assembly:
    • You must install the oxygen regulator assembly before reinstalling the oxygen valve assembly
    • When reinstalling the oxygen valve, make sure the oxygen regulator and oxygen flow sensor are fully installed to the oxygen valve assembly
    • Always inspect the O-rings between interconnecting parts, and replace them if they are visibly damaged or rough to the touch.
    • Always use new O-rings supplied with replacement parts
    • Lightly lubricate O-rings with Krytox GPL226 lubricant when installing, and relubricate at every reinstallation
  2. Philips Respironics V200 Esprit Oxygen Valve Replacement: stap 2, afbeelding 1 van 1
    • Remove the oxygen flow sensor
    • (Instructions found in Chapter 10.26 of the Respironics V200/Esprit Ventilator Service Manual.)
    • Careful! Do not cut the tie wrap or disconnect the O2 F/S cable from the flow sensor.
  3. Philips Respironics V200 Esprit Oxygen Valve Replacement: stap 3, afbeelding 1 van 1
    • Remove the air flow sensor
    • (Instructions found in Chapter 10.27 of the Respironics V200/Esprit Ventilator Service Manual.)
    • Careful! Do not cut the tie wrap or disconnect the AIR F/S cable from the flow sensor.
  4. Philips Respironics V200 Esprit Oxygen Valve Replacement: stap 4, afbeelding 1 van 1
    • Remove the air valve assembly
    • (Instructions found in Chapter 10.30 of the Respironics V200/Esprit Ventilator Service Manual.)
    • Disconnect the two MTR O2 cables on the oxygen valve from the mating MTR O2 cable
    • Disconnect the CROSS SOL cable from the crossover solenoid valve
    • Using a 8-mm socket with extension, remove the three bolts that hold the oxygen valve bracket
    • Slowly pull the oxygen valve assembly away from the oxygen regulator
Conclusie
Grace Gius
505 Reputatie
3 handleidingen geschreven
Cal Poly, Team S1-G4, Zimmerman Spring 2020 Lid van Cal Poly, Team S1-G4, Zimmerman Spring 2020
CPSU-ZIMMERMAN-S20S1G4
5 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 330
