Inleiding
This guide will show you the process of removing the circuit board from the Philips Respironics System One REMstar ventilator. The circuit board controls all of the operations of the device, including critical pressure and volume managements, so it’s key that the board is functioning correctly if the device is in use on a patient. Be sure to run thorough diagnostics tests on the device after a replacement has been made to ensure the device is functioning as intended.
Wat je nodig hebt
Turn the device upside down so that the rubber feet are facing you.
Use a Torx TR15 screwdriver to remove the two 46.5mm screws located on the back.
2 opmerkingen
Do you happen to have a part number or link for replacement pcb?
Ce anume nu funcționează ?
