Inleiding
This guide will help users to replace the inner battery of the Philips PD9000/37 DVD Player.
Wat je nodig hebt
Lay the player flat so the bottom outside is showing. Using the Phillips #0 screwdriver, unscrew all the housing screws on the bottom of the player.
Have the player sitting upright, remove the rubber stoppers in order to get to the screw. Unscrew the inside screws by the screen using the Philips #0 screwdriver.
Remove the rubber stoppers for the bottom two screws as well. Unscrew the middle two screws.
Start removing the inside black face plate of the player by using a prying method between the white outer housing and the black face plate with a metal spudger.
Pull the black face plate off once you have pried it from the white housing. The bottom inside layer should pop off.
Using the same prying method with the metal spudger, start prying off the screens white outer housing.
Take the metal rounded rectangle spudger and place under battery edge.
press down hard on held end of spudger, you will hear the battery un-stick.
5 andere personen hebben deze handleiding voltooid.
3 opmerkingen
Yeah. Where can I get the battery?
This tutorial is completely worthless if one doesn't have a battery to replace the one removed. Now two people have asked where to get a replacement yet you have not responded. Undoubtedly countless others have come by looking for a suitable replacement and saw that there was no response and no solution. Congratulations on helping no one. It would seem you're nothing more than a blowhard, a big show off, “Oh look at me I am fixing my bad battery. Aren't you impressed?” I'm not.
