Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
If the beard comb does not move, there may be a problem with the inside of the zoom lock ring, and the zoom lock precision notch may need to be replaced. Follow this guide to replace the zoom lock precision notch.
Onderdelen
Geen onderdelen opgegeven.
  1. Remove the comb from the top of the trimmer.
    • Remove the comb from the top of the trimmer.
  2. Place your thumb underneath the blade and push upward to remove it. Place your thumb underneath the blade and push upward to remove it.
    • Place your thumb underneath the blade and push upward to remove it.
  3. Hold trimmer towards you as shown in the diagram. Insert your prying tool/metal spudger into the marked area.
    • Hold trimmer towards you as shown in the diagram.
    • Insert your prying tool/metal spudger into the marked area.
  4. Apply gentle pressure and begin prying open the back panel. Separate the panel one notch at a time.  Listen carefully as you're prying the panel apart and notice each individual notch release. Separate the panel one notch at a time.  Listen carefully as you're prying the panel apart and notice each individual notch release.
    • Apply gentle pressure and begin prying open the back panel.
    • Separate the panel one notch at a time. Listen carefully as you're prying the panel apart and notice each individual notch release.
  5. De essentiƫle toolkit
    De meest behulpzame tools in onze meest compacte kit.
    Koop nu
    Koop nu
  6. Pull the trimmer apart using your hands once the panel is at least halfway apart. Pull the wires attached to the battery off of the power connectors before completely removing the back panel. Pull the wires attached to the battery off of the power connectors before completely removing the back panel.
    • Pull the trimmer apart using your hands once the panel is at least halfway apart.
    • Pull the wires attached to the battery off of the power connectors before completely removing the back panel.
  7. Hold the trimmer towards you. Place the metal spudger tool in the marked area.
    • Hold the trimmer towards you.
    • Place the metal spudger tool in the marked area.
  8. Apply gentle pressure and begin prying the front panel.
    • Apply gentle pressure and begin prying the front panel.
    • Separate the front panel one notch at a time.
  9. Pull the trimmer apart using your hands once the panel is at least halfway apart. Pull the trimmer apart using your hands once the panel is at least halfway apart.
  10. Locate the zoom lock precision notch in the back panel of the Beardtrimmer
    • Locate the zoom lock precision notch in the back panel of the Beardtrimmer
  11. Set the zoom lock wheel to the lowest setting
    • Set the zoom lock wheel to the lowest setting
  12. Rotate the trimmer so that the motor is facing you. Now gently push down the zoom lock wheel until the white button is not showing.
    • Rotate the trimmer so that the motor is facing you.
    • Now gently push down the zoom lock wheel until the white button is not showing.
  13. Rotate the beardtrimmer again so that the battery is facing you. With the help of the metal spudger, apply gentle pressure on top of the wheel to remove the zoom lock precision notch . With the help of the metal spudger, apply gentle pressure on top of the wheel to remove the zoom lock precision notch .
    • Rotate the beardtrimmer again so that the battery is facing you.
    • With the help of the metal spudger, apply gentle pressure on top of the wheel to remove the zoom lock precision notch .
Conclusie
ilan
161 Reputatie
1 Handleiding geschreven
USF Tampa, Team 15-2, Blackwell Fall 2015 Lid van USF Tampa, Team 15-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G2
4 Leden
6 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 15
Altijd: 3,523
