Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Place your thumb underneath the blade and push upward to remove it.
Hold trimmer towards you as shown in the diagram.
Insert your prying tool/metal spudger into the marked area.
Apply gentle pressure and begin prying open the back panel.
Separate the panel one notch at a time. Listen carefully as you're prying the panel apart and notice each individual notch release.
Pull the trimmer apart using your hands once the panel is at least halfway apart.
Pull the wires attached to the battery off of the power connectors before completely removing the back panel.
Hold the trimmer towards you.
Place the metal spudger tool in the marked area.
Apply gentle pressure and begin prying the front panel.
Separate the front panel one notch at a time.
