Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
In order to access the internal components of the beardtrimmer, the front and back panels must be removed. This guide will instruct you on the process.
Onderdelen
Geen onderdelen opgegeven.
  1. Remove the comb from the top of the trimmer.
    • Remove the comb from the top of the trimmer.
  2. Place your thumb underneath the blade and push upward to remove it. Place your thumb underneath the blade and push upward to remove it.
    • Place your thumb underneath the blade and push upward to remove it.
  3. Hold trimmer towards you as shown in the diagram. Insert your prying tool/metal spudger into the marked area.
    • Hold trimmer towards you as shown in the diagram.
    • Insert your prying tool/metal spudger into the marked area.
  4. De essentiële toolkit
    De meest behulpzame tools in onze meest compacte kit.
    Koop nu
    Koop nu
  5. Apply gentle pressure and begin prying open the back panel. Separate the panel one notch at a time.  Listen carefully as you're prying the panel apart and notice each individual notch release. Separate the panel one notch at a time.  Listen carefully as you're prying the panel apart and notice each individual notch release.
    • Apply gentle pressure and begin prying open the back panel.
    • Separate the panel one notch at a time. Listen carefully as you're prying the panel apart and notice each individual notch release.
  6. Pull the trimmer apart using your hands once the panel is at least halfway apart. Pull the wires attached to the battery off of the power connectors before completely removing the back panel. Pull the wires attached to the battery off of the power connectors before completely removing the back panel.
    • Pull the trimmer apart using your hands once the panel is at least halfway apart.
    • Pull the wires attached to the battery off of the power connectors before completely removing the back panel.
  7. Hold the trimmer towards you. Place the metal spudger tool in the marked area.
    • Hold the trimmer towards you.
    • Place the metal spudger tool in the marked area.
  8. Apply gentle pressure and begin prying the front panel.
    • Apply gentle pressure and begin prying the front panel.
    • Separate the front panel one notch at a time.
  9. Pull the trimmer apart using your hands once the panel is at least halfway apart. Pull the trimmer apart using your hands once the panel is at least halfway apart.
Conclusie
Darren Chu
1.385 Reputatie
3 handleidingen geschreven
USF Tampa, Team 15-2, Blackwell Fall 2015 Lid van USF Tampa, Team 15-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G2
4 Leden
6 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 64
