Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Place thumb underneath the blade; push upward to pop the blade off.
Grab the plastic arms with the tweezers and pull them apart from the base.
Remove the plastic casing from the underside of the blade.
Remove the last plastic casing from the front side of the blade.
Pull the spring off from the base with the tweezers.
Pull the blade apart from the base with the tweezers.
21 andere personen hebben deze handleiding voltooid.
10 opmerkingen
what about getting it back togeather
Sadly it is impossible to put the parts back together. It isnt just as simple as start with the end. Normally i am quite good with fixing stuff. But this time... maybe because mine is broken? A guide for putting it back together should show me where it g9es wrong. But thanks for the guide anyways, thanks for the time you put into it.
Now I can't get it back :-(
It's easy to get it back.i assembled mine a lot of times... Guys just try
