Inleiding
We will show how to replace the housing of the device, on both the front or rear. This guide will be useful if the housing is cracked or broken, not so much so if the device itself does not work. No special skills are required for this easy fix! Prior to beginning the assembly please purchase replacements from the links provided on the troubleshooting page.
Wat je nodig hebt
Remove the two T8 2 mm Phillips screws on the back housing.
Now, you can put the new housing on. To reassemble your device, follow these instructions in reverse order.
