Ga door naar hoofdinhoud
Philips DVP642 Power Supply Replacement
Wat je nodig hebt
  1. Philips DVP642 Power Supply Replacement, Top Panel: stap 1, afbeelding 1 van 2 Philips DVP642 Power Supply Replacement, Top Panel: stap 1, afbeelding 2 van 2
    • Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
    • Remove five 7.5 mm Phillips screws on the back of the player.
  2. Philips DVP642 Power Supply Replacement: stap 2, afbeelding 1 van 2 Philips DVP642 Power Supply Replacement: stap 2, afbeelding 2 van 2
    • Lift the top panel from the back and remove. It should come off without being forced. There is a lip near the front so you many need to slide the top panel back slightly to remove it.
  3. Philips DVP642 Power Supply Replacement, Power Supply: stap 3, afbeelding 1 van 2 Philips DVP642 Power Supply Replacement, Power Supply: stap 3, afbeelding 2 van 2
    • Slide the power cord out from the case.
    • Be sure not to lose the rubber clip that is wrapped around the cord.
  4. Philips DVP642 Power Supply Replacement: stap 4, afbeelding 1 van 1
    • Remove the ribbon attached to the power supply by pushing the latch and gently pulling up.
  5. Philips DVP642 Power Supply Replacement: stap 5, afbeelding 1 van 2 Philips DVP642 Power Supply Replacement: stap 5, afbeelding 2 van 2
    • Now remove this ribbon wire by grasping the white head firmly and pulling up gently.
  6. Philips DVP642 Power Supply Replacement: stap 6, afbeelding 1 van 2 Philips DVP642 Power Supply Replacement: stap 6, afbeelding 2 van 2
    • Remove these two 7.5m Phillips screws and the matching set at the other end of the supply.
    • Now remove the ribbon that attaches the power supply to the motherboard by grasping the white head and gently pulling up.
  7. Philips DVP642 Power Supply Replacement: stap 7, afbeelding 1 van 3 Philips DVP642 Power Supply Replacement: stap 7, afbeelding 2 van 3 Philips DVP642 Power Supply Replacement: stap 7, afbeelding 3 van 3
    • Remove the last screw.
    • Pinch this plastic prong and slide the power supply up and over it. The power supply should lift free.
  8. Philips DVP642 Power Supply Replacement: stap 8, afbeelding 1 van 2 Philips DVP642 Power Supply Replacement: stap 8, afbeelding 2 van 2
    • Your power supply is now free!
    • If the fuse circled here is blown (the small wire in the glass tube is missing or broken), remove it by pinching it tightly and pulling it straight out.
    • You can find a new fuse here.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Toby Goldsteinholm
360 Reputatie
2 handleidingen geschreven
Cal Poly, Team 21-20, Maness Fall 2011 Lid van Cal Poly, Team 21-20, Maness Fall 2011
CPSU-MANESS-F11S21G20
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 45
Altijd: 13,375
