Inleiding
This is a guide on how to replace the speakers on a Philips DS3000/37 Audio Dock. Because this repair requires soldering, the soldering technique page linked here might be helpful. Hoe moet je (de-)solderen?
Wat je nodig hebt
Pry off the front fascia by inserting a plastic opening tool between the fascia and white casing.
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
i hardly difficult to treat 2 defective speakers. i find the flat cable a little loose on the main plate. thank you!!!
