Inleiding
Ensure to have the required spare parts lying next to you before your start disassembling the device.
You should also have a little bowl ready to set aside screws and other small parts.
Wat je nodig hebt
Put on the Anti-Static Wrist Strap and clamp the end of the band to an unpainted spot of a radiator.
Unscrew the six Torx #4 (5,3 mm) screws from both sides of the device
Remove the mounting spring from the speaker with a pair of tweezers.
Unscrew the eight Torx #4 (5,0 mm) screws from the motherboard.
These two screws connect the motherboard with the sliding cage. In this guide they are removed as well. Hence this is not compulsory you can decide for yourself whether you want to remove them now or later.
To reassemble your device, follow these instructions in reverse order beginning with step 15.
2 opmerkingen
Großes Lob. Klare Anleitung. Scharfe Fotos. Gibt von 10/ 10 Punkte.
Hab noch vergessen, was an dem Gerät war. Der Schiebeschalter ging sehr schwer. Vermutlich war irgend etwas klebriges darunter. Ich habe den Schlitten gesäubert. Er geht wieder. Vielen Dank.
