Inleiding
Follow the procedure outlined in this guide to remove and install a speaker.
  1. Pry off the four white feet with the pointed end of the spudger
    • Pry off the four white feet with the pointed end of the spudger
  2. Unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
    • Unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
  3. Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
    • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
    • The connectors on the panel are fragile and may break.
  4. Android Fix Kits
    Slechts één reparatie scheidt jou van een nieuw scherm of een nieuwe batterij.
    Nu winkelen
    Android Fix Kits
    Nu winkelen
  5. Carefully pull up and out the four electrical connectors and the two ribbon connectors connecting the bottom panel and the dock. Electrical Connectors Ribbon Connectors
    • Carefully pull up and out the four electrical connectors and the two ribbon connectors connecting the bottom panel and the dock.
    • Electrical Connectors
    • Ribbon Connectors
    • The cables do not have a lot of slack in them. Be careful not to break the connectors.
    • One wire is soldered onto the bottom panel. Be careful not to break this bond.
  6. Unscrew the two 6 mm Phillips #00 screws attaching the back panel to device.
    • Unscrew the two 6 mm Phillips #00 screws attaching the back panel to device.
  7. Slide the back panel towards top of the device and lift away from the device to detach back panel. Slide the back panel towards top of the device and lift away from the device to detach back panel. Slide the back panel towards top of the device and lift away from the device to detach back panel.
    • Slide the back panel towards top of the device and lift away from the device to detach back panel.
  8. Unscrew the four 16 mm Phillips #2 screws attaching the speaker unit to device.
    • Unscrew the four 16 mm Phillips #2 screws attaching the speaker unit to device.
  9. Slide the speaker towards the bottom of the device to remove. Slide the speaker towards the bottom of the device to remove.
    • Slide the speaker towards the bottom of the device to remove.
Conclusie
Graham Rolph
1 Reputatie
2 handleidingen geschreven
Cal Poly, Team 3-48, Amido Spring 2013 Lid van Cal Poly, Team 3-48, Amido Spring 2013
CPSU-AMIDO-S13S3G48
4 Leden
6 handleidingen geschreven
Voeg een opmerking toe
Bekijk statistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 9
Aller tijden: 653
