Ga door naar hoofdinhoud
Philips DC320 37 Headphone or Power Jack Replacement
Wat je nodig hebt
  1. Philips DC320 37 Headphone or Power Jack Replacement, Docking entertainment system: stap 1, afbeelding 1 van 1
    • Pry off the four white feet with the pointed end of the spudger
  2. Philips DC320 37 Headphone or Power Jack Replacement: stap 2, afbeelding 1 van 1
    • Gently unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
  3. Philips DC320 37 Headphone or Power Jack Replacement: stap 3, afbeelding 1 van 1
    • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
    • The connectors on the panel are fragile and may break.
  4. Philips DC320 37 Headphone or Power Jack Replacement: stap 4, afbeelding 1 van 3 Philips DC320 37 Headphone or Power Jack Replacement: stap 4, afbeelding 2 van 3 Philips DC320 37 Headphone or Power Jack Replacement: stap 4, afbeelding 3 van 3
    • Carefully pull up and out the four electrical connectors and two ribbon connectors that connect the bottom panel to the dock.
    • Electrical Connectors
    • Ribbon Connectors
    • The cables do not have a lot of slack in them. Be careful not to break the connectors.
    • One wire is soldered onto the bottom panel. Be careful not to break this bond.
  5. Philips DC320 37 Headphone or Power Jack Replacement, Headphone or Power Jack: stap 5, afbeelding 1 van 1
    • Unscrew the two 5 mm Phillips #00 screws attaching white support bracket to the body of the device.
  6. Philips DC320 37 Headphone or Power Jack Replacement: stap 6, afbeelding 1 van 1
    • Unscrew the two 5 mm Phillips #00 screws from green Headphone/Power electronics board to detach from white support bracket.
  7. Philips DC320 37 Headphone or Power Jack Replacement: stap 7, afbeelding 1 van 1
    • Separate the white suport bracket from the headphone/power electronics board.
Conclusie
Graham Rolph
1 Reputatie
2 handleidingen geschreven
Cal Poly, Team 3-48, Amido Spring 2013 Lid van Cal Poly, Team 3-48, Amido Spring 2013
CPSU-AMIDO-S13S3G48
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,255
