Ga door naar hoofdinhoud
Philips DC320 37 Bottom Button Circuit Board Replacement
Wat je nodig hebt
  1. Philips DC320 37 Bottom Button Circuit Board Replacement, Docking entertainment system: stap 1, afbeelding 1 van 1
    • Pry off the four white feet with the pointed end of the spudger
  2. Philips DC320 37 Bottom Button Circuit Board Replacement: stap 2, afbeelding 1 van 1
    • Gently unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
  3. Philips DC320 37 Bottom Button Circuit Board Replacement: stap 3, afbeelding 1 van 1
    • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
    • The connectors on the panel are fragile and may break.
  4. Philips DC320 37 Bottom Button Circuit Board Replacement: stap 4, afbeelding 1 van 3 Philips DC320 37 Bottom Button Circuit Board Replacement: stap 4, afbeelding 2 van 3 Philips DC320 37 Bottom Button Circuit Board Replacement: stap 4, afbeelding 3 van 3
    • Carefully pull up and out the four electrical connectors and two ribbon connectors that connect the bottom panel to the dock.
    • Electrical Connectors
    • Ribbon Connectors
    • The cables do not have a lot of slack in them. Be careful not to break the connectors.
    • One wire is soldered onto the bottom panel. Be careful not to break this bond.
  5. Philips DC320 37 Bottom Button Circuit Board Replacement, Bottom Button Circuit Board: stap 5, afbeelding 1 van 1
    • Unscrew the ten 6 mm Phillips #00 screws holding the board in place.
  6. Philips DC320 37 Bottom Button Circuit Board Replacement: stap 6, afbeelding 1 van 1
    • Pull the board out from the dock
Conclusie
Greg Lane
39 Reputatie
4 handleidingen geschreven
Cal Poly, Team 3-48, Amido Spring 2013 Lid van Cal Poly, Team 3-48, Amido Spring 2013
CPSU-AMIDO-S13S3G48
4 Leden
6 handleidingen geschreven
Één opmerking
My philips dc 320 /37 A do not sown time digits and frecvency digits . Where can I find schematic diagram?
Thank you
chioreangheorghe - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 884
