Ga door naar hoofdinhoud
Philips BiPAP S/T Blower Replacement
Medische apparatuur
Noch iFixit, noch deze reparatiehandleiding worden onderschreven door of zijn gelieerd aan de fabrikant van de desbetreffende medische apparatuur.
Wat je nodig hebt
Video overzicht
  1. Philips BiPAP S/T Blower  Replacement, Blower: stap 1, afbeelding 1 van 1
    • Remove the UI Knob by pulling it straight out.
  2. Philips BiPAP S/T Blower  Replacement: stap 2, afbeelding 1 van 1
    • Remove the top cover by using a Torx T15 to remove the 2 screws on the back of the enclosure.
  3. Philips BiPAP S/T Blower  Replacement: stap 3, afbeelding 1 van 1
    • Remove the Main PCA by removing the wiring harnesses and squeezing the 2 standoffs in the corners of the board.
  4. Philips BiPAP S/T Blower  Replacement: stap 4, afbeelding 1 van 1
    • Remove the Blower Cap by using the T8 Torx screwdriver to remove the 7 screws that secure the Cap to the enclosure.
    • Lift the Blower Assembly out of the blower housing.
    • Remove the blower Outlet Bellows from the blower assembly.
    • Place the New outlet bellows onto the blower assembly.
  5. Philips BiPAP S/T Blower  Replacement: stap 7, afbeelding 1 van 1
    • Align the stands located on the bottom of the blower assembly with the holes in the blower housing.
Conclusie
Benjamin LaVigna
243 Reputatie
1 Handleiding geschreven
Cal Poly, Team S7-G3, Paton Spring 2020 Lid van Cal Poly, Team S7-G3, Paton Spring 2020
CPSU-PATON-S20S7G3
3 Leden
3 handleidingen geschreven
Één opmerking
this was super helpful. i yanked a working motor/blower from a slightly older system one unit that had a dead humidifier circuit(found it had melted the connector inside) and moved it to my newer bipap unit. works great, dead silent. mine had bad bearings…so loud. great article. thank you for saving me money, time…..SLEEP!
Jon Harmon - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 22
Altijd: 2,745
