Inleiding
Change headlamp bulbs on Peugeot Boxer van (2006 onwards).
Wat je nodig hebt
Open the passenger side door to find the bonnet release catch.
Pull the catch down and towards you to release the bonnet of the van.
Once the bonnet is loosened, find the yellow handle of the secondary bonnet catch by feeling underneath
Once you locate the catch, push the bonnet catch upwards, this will release the bonnet
Use the strut, located to the right of the hood to prop open the bonnet.
Remove the electrical connection from the old bulb (it should just pull off).
With needle-nosed pliers, carefully 'wiggle' the old bulb out from its housing.
Locate your new bulb. Taking care to make sure it is the right way up, push it firmly into place until you feel it clip in.
