Ga door naar hoofdinhoud
Petzl E03 050 Headlamp Battery Replacement
Wat je nodig hebt
  1. Petzl E03 050 Headlamp Battery Replacement, Remove the Cover: stap 1, afbeelding 1 van 1
    • Remove the back cover of the battery housing (found behind the mount assembly) by pulling the small tab on the bottom right corner.
  2. Petzl E03 050 Headlamp Battery Replacement, Remove the Old Batteries: stap 2, afbeelding 1 van 1
    • Remove the old batteries by pulling outward the positive end of each battery.
  3. Petzl E03 050 Headlamp Battery Replacement, Insert the New Batteries: stap 3, afbeelding 1 van 1
    • Insert the new batteries by inserting the negative end of the battery into the negative side of the battery compartment and pushing the positive end of the battery into the positive side of battery compartment.
  4. Petzl E03 050 Headlamp Battery Replacement, Reattach the Cover: stap 4, afbeelding 1 van 1
    • Reattach the back cover of the battery housing by pushing in the bottom half and then pressing the rest of the cover into place.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Mike
331 Reputatie
3 handleidingen geschreven
Baylor, Team 8-10, Williams Fall 2014 Lid van Baylor, Team 8-10, Williams Fall 2014
BU-WILLIAMS-F14S8G10
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 75
Altijd: 5,214
