Ga door naar hoofdinhoud
Petnet SmartFeeder SF10E Battery Replacement
Wat je nodig hebt
  1. Petnet SmartFeeder SF10E Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Petnet SmartFeeder SF10E Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Petnet SmartFeeder SF10E Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Eject the SmartBowl by pressing the button located at the front of the SmartFeeder base.
    • Remove the metal tray by using both hands and pulling out the bowl towards you.
  2. Petnet SmartFeeder SF10E Battery Replacement: stap 2, afbeelding 1 van 2 Petnet SmartFeeder SF10E Battery Replacement: stap 2, afbeelding 2 van 2
    • Turn the bowl tray side down by using both hands.
    • Remove seven 11 mm screws by using the Phillips #1 screwdriver.
  3. Petnet SmartFeeder SF10E Battery Replacement: stap 3, afbeelding 1 van 2 Petnet SmartFeeder SF10E Battery Replacement: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Take the battery out of the SmartBowl with tweezers, avoid pulling on any wires.
    • Hold the SmartBowl down using one hand while using the other hand to remove the battery.
  4. Petnet SmartFeeder SF10E Battery Replacement: stap 4, afbeelding 1 van 2 Petnet SmartFeeder SF10E Battery Replacement: stap 4, afbeelding 2 van 2
    • Remove the tape, closest to the four white connectors, with your hands.
    • Keep the wires attached to the tape for easy reassembly.
  5. Petnet SmartFeeder SF10E Battery Replacement: stap 5, afbeelding 1 van 2 Petnet SmartFeeder SF10E Battery Replacement: stap 5, afbeelding 2 van 2
    • Trace the wires with your hands from the battery to the motherboard.
    • Detach the three-prong connector between the battery and the motherboard by pulling the white connectors with your hands.
    • Hold on to the sockets on the motherboard or you could accidentally pull off the entire assembly.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kristin Villanueva
370 Reputatie
2 handleidingen geschreven
Cal Poly, Team S13-G7, White Fall 2018 Lid van Cal Poly, Team S13-G7, White Fall 2018
CPSU-WHITE-F18S13G7
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 571
