Ga door naar hoofdinhoud
Petnet SmartFeeder SF10E 12 Pin Connector Replacement
Wat je nodig hebt
  1. Petnet SmartFeeder SF10E 12 Pin Connector Replacement, 12 Pin Connector: stap 1, afbeelding 1 van 3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement, 12 Pin Connector: stap 1, afbeelding 2 van 3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement, 12 Pin Connector: stap 1, afbeelding 3 van 3
    • Eject the SmartBowl by pressing the button located at the front of the SmartFeeder base.
  2. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: stap 2, afbeelding 1 van 3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: stap 2, afbeelding 2 van 3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: stap 2, afbeelding 3 van 3
    • Remove the food tub by twisting it counter-clockwise with both hands and lifting it up.
  3. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: stap 3, afbeelding 1 van 1
    • Remove the black plastic gasket from the top of the SmartFeeder by placing your fingers on the side of it and lifting up.
    • It should come off easily.
  4. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: stap 4, afbeelding 1 van 1
    • Flip over the SmartFeeder by using both hands.
    • Partially open the outer case of the SmartFeeder by wedging an iFixit Opening Tool on each side.
  5. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: stap 5, afbeelding 1 van 2 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: stap 5, afbeelding 2 van 2
    • Turn the SmartFeeder on its side and with one hand on the base, carefully pull out the central section.
    • Place the bottom piece of the device right-side up.
  6. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: stap 6, afbeelding 1 van 2 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: stap 6, afbeelding 2 van 2
    • Remove one 10 mm screw by using the Phillips #1 screwdriver.
    • Remove the plastic retaining piece for the daughterboard by pulling it out with one hand.
  7. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: stap 7, afbeelding 1 van 3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: stap 7, afbeelding 2 van 3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: stap 7, afbeelding 3 van 3
    • Pull the daughterboard out of the device and remove the three-prong connectors by using your hands.
    • Hold onto the sockets on the motherboard or you could accidentally pull off the entire assembly.
Conclusie
Ashley Kim
187 Reputatie
1 Handleiding geschreven
Cal Poly, Team S13-G7, White Fall 2018 Lid van Cal Poly, Team S13-G7, White Fall 2018
CPSU-WHITE-F18S13G7
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 317
