Inleiding
Use this guide to replace a pump on your Petmate 29027 pet flower fountain. The water pump fits a pet water fountain and produces water movement. It made up of the impeller, stator, and intake plate. If the fountain feels slimy, leaking, too loud noise, or stopped working, it may need to be replaced by the pump.
Sometimes, you may only need to clean the pump rather than replace it. If cleaning does not work, please carefully follow the operating instructions to replace the pump. Before replacing the pump, make sure to power off your pet fountain completely and disconnect from any external power source. After replacement, please test the fountain and ensure the pump works well.
Wat je nodig hebt
Unplug the fountain from the electrical source and disconnect the inline plug.
Remove the lid.
Empty water from the fountain
Reach in the bowl and lift up the pump.
