Ga door naar hoofdinhoud
Petmate 29027 Fountain Lid and Pump Replacement
Wat je nodig hebt
  1. Petmate 29027 Fountain Lid and Pump Replacement, Fountain Lid and Pump: stap 1, afbeelding 1 van 3 Petmate 29027 Fountain Lid and Pump Replacement, Fountain Lid and Pump: stap 1, afbeelding 2 van 3 Petmate 29027 Fountain Lid and Pump Replacement, Fountain Lid and Pump: stap 1, afbeelding 3 van 3
    • Unplug the fountain from the electrical source and disconnect the inline plug.
    • Remove the lid.
    • Empty water from the fountain
    • Reach in the bowl and lift up the pump.
  2. Petmate 29027 Fountain Lid and Pump Replacement: stap 2, afbeelding 1 van 3 Petmate 29027 Fountain Lid and Pump Replacement: stap 2, afbeelding 2 van 3 Petmate 29027 Fountain Lid and Pump Replacement: stap 2, afbeelding 3 van 3
    • Unclip the lid and intake plate using a fingernail.
  3. Petmate 29027 Fountain Lid and Pump Replacement: stap 3, afbeelding 1 van 2 Petmate 29027 Fountain Lid and Pump Replacement: stap 3, afbeelding 2 van 2
    • Pry out the impeller (4 white bladed propellers) which is held in place magnetically.
    • You can use a fingernail or small needle nose pliers to get under the plastic blade and lift it out.
  4. Petmate 29027 Fountain Lid and Pump Replacement: stap 4, afbeelding 1 van 3 Petmate 29027 Fountain Lid and Pump Replacement: stap 4, afbeelding 2 van 3 Petmate 29027 Fountain Lid and Pump Replacement: stap 4, afbeelding 3 van 3
    • Clean the parts with warm soapy water and reassemble them.
    • Be sure to rinse thoroughly with fresh water.
    • Cleaning the motor with white vinegar (150ml) can increase disinfecting and hard water removal.
  5. Petmate 29027 Fountain Lid and Pump Replacement: stap 5, afbeelding 1 van 2 Petmate 29027 Fountain Lid and Pump Replacement: stap 5, afbeelding 2 van 2
    • Replace the pump into the original location.
    • Press down on the pump to engage the suction cups.
    • Place the fountain lid in the right place.
  6. Petmate 29027 Fountain Lid and Pump Replacement: stap 6, afbeelding 1 van 2 Petmate 29027 Fountain Lid and Pump Replacement: stap 6, afbeelding 2 van 2
    • Replug the fountain into electricity.
    • Add water as needed.
    • Never let the water level fall lower than the min fill line.
Eindstreep
Shidie Ren
133 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 428
