Ga door naar hoofdinhoud
Pentax ZX-5n Flash Pivot Replacement
Wat je nodig hebt
  1. Pentax ZX-5n Flash Pivot Replacement, Remove back cover: stap 1, afbeelding 1 van 1
    • Push down on the screw to depress the spring loaded hinge and release the door.
  2. Pentax ZX-5n Flash Pivot Replacement, Remove bottom cover: stap 2, afbeelding 1 van 1
    • Remove six 5.3 mm #00 screws.
    • Remove one 3.4 mm #00 screw.
    • The short screw has a machine thread and screws into the plate underneath. The rest screw into the plastic body.
  3. Pentax ZX-5n Flash Pivot Replacement, Remove left front cover: stap 3, afbeelding 1 van 1
    • Remove three 5.3 mm #00 screws (the bottom-most screw is not always present).
    • Remove one 7.3 mm #00 screw.
    • Remove the remote trigger cover.
  4. Pentax ZX-5n Flash Pivot Replacement, Remove front cover: stap 4, afbeelding 1 van 2 Pentax ZX-5n Flash Pivot Replacement, Remove front cover: stap 4, afbeelding 2 van 2
    • Remove two 5.3 mm #00 screw.
    • Gently lift up on the flash housing to help remove the cover if necessary.
  5. Pentax ZX-5n Flash Pivot Replacement, Remove right front cover: stap 5, afbeelding 1 van 1
    • Remove two 3.9 mm #00 screws.
  6. Pentax ZX-5n Flash Pivot Replacement, Remove eye cup: stap 6, afbeelding 1 van 1
    • Slide the eye cup up and off to access the screws underneath.
  7. Pentax ZX-5n Flash Pivot Replacement, Unscrew top cover: stap 7, afbeelding 1 van 3 Pentax ZX-5n Flash Pivot Replacement, Unscrew top cover: stap 7, afbeelding 2 van 3 Pentax ZX-5n Flash Pivot Replacement, Unscrew top cover: stap 7, afbeelding 3 van 3
    • Remove two 5.3 mm #00 screws by the eyepiece.
    • Remove one 6.8 mm #00 screw in the battery compartment.
    • Remove one 7.0 mm #00 screw near the take up spool.
  8. Pentax ZX-5n Flash Pivot Replacement, Lift top cover: stap 8, afbeelding 1 van 1
    • Lift the cover so it is just free of the body. It is still attached by several wires.
  9. Pentax ZX-5n Flash Pivot Replacement, Discharge flash capacitors: stap 9, afbeelding 1 van 1
    • Use a 1kΩ-10kΩ resistor to discharge the capacitor. Place the resistor between the blue wire, exposed in the previous step, and ground.
    • The flash capacitors store energy at a very high voltage. Failing to discharge the capacitors properly could result in personal injury and/or damage to the camera.
  10. Pentax ZX-5n Flash Pivot Replacement, Unsolder flash connections: stap 10, afbeelding 1 van 1
    • Unsolder one green wire.
    • Unsolder one blue wire.
    • Unsolder one brown wire.
    • Unsolder one black wire.
  11. Pentax ZX-5n Flash Pivot Replacement, Unsolder remaining connections: stap 11, afbeelding 1 van 3 Pentax ZX-5n Flash Pivot Replacement, Unsolder remaining connections: stap 11, afbeelding 2 van 3 Pentax ZX-5n Flash Pivot Replacement, Unsolder remaining connections: stap 11, afbeelding 3 van 3
    • Pull black wire out from its routed location.
    • Unsolder flex connector
    • Be careful not to overheat the flex circuit. Work in short durations. Allow for cool downs in between if necessary.
    • Some repairs can be performed with the top cover still connected but the flex connection is fragile and easily damaged.
  12. Pentax ZX-5n Flash Pivot Replacement, Pop up the flash: stap 12, afbeelding 1 van 1
    • Push the release button to pop up the flash.
  13. Pentax ZX-5n Flash Pivot Replacement, Remove flash cover: stap 13, afbeelding 1 van 3 Pentax ZX-5n Flash Pivot Replacement, Remove flash cover: stap 13, afbeelding 2 van 3 Pentax ZX-5n Flash Pivot Replacement, Remove flash cover: stap 13, afbeelding 3 van 3
    • Remove two 2.9mm #000 screws.
    • Remove two 4.4 mm #00 screws.
    • Close the flash and lift off the top cover.
  14. Pentax ZX-5n Flash Pivot Replacement, Remove flash latch: stap 14, afbeelding 1 van 3 Pentax ZX-5n Flash Pivot Replacement, Remove flash latch: stap 14, afbeelding 2 van 3 Pentax ZX-5n Flash Pivot Replacement, Remove flash latch: stap 14, afbeelding 3 van 3
    • Remove the latch spring.
    • Remove the latch plate. The flash will try to pop up when it is removed.
  15. Pentax ZX-5n Flash Pivot Replacement, Remove pop up spring: stap 15, afbeelding 1 van 1
    • Release the spring arm from the post.
    • Remove the pop up spring.
  16. Pentax ZX-5n Flash Pivot Replacement, Remove the flash pivot: stap 16, afbeelding 1 van 2 Pentax ZX-5n Flash Pivot Replacement, Remove the flash pivot: stap 16, afbeelding 2 van 2
    • Remove one 3.3 mm #00 screw.
    • Hold the pivot in place while unscrewing.
  17. Pentax ZX-5n Flash Pivot Replacement, Install screw: stap 17, afbeelding 1 van 1
    • When using the 3D printed part supplied on the device page, install a 4mm #00 screw in the end of the pivot to hold it together.
Conclusie
Sam Gustafson
7.682 Reputatie
42 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 29
Altijd: 616
