Ga door naar hoofdinhoud
Pentax Optio WP Battery and SD Card Replacement
  1. Pentax Optio WP Battery and SD Card Replacement, Battery and SD Card: stap 1, afbeelding 1 van 1
    • The camera used to make this manual does not contain a battery or SD card
    • Orient the camera so you are looking at the bottom and the battery compartment is on the right hand side.
  2. Pentax Optio WP Battery and SD Card Replacement: stap 2, afbeelding 1 van 2 Pentax Optio WP Battery and SD Card Replacement: stap 2, afbeelding 2 van 2
    • Unlock the battery compartment by sliding the lock switch to the unlock position (away from the arrow).
    • Firmly push the battery cover to the right and swing open.
    • The battery will be located in the larger bottom slot. Slide the plastic orange tab to remove the battery.
    • The SD card will be located in the smaller, top slot. Push the SD card directly in to hear a small clicking sound. Then pull out the SD card.
Conclusie
Olivia Nixon
429 Reputatie
4 handleidingen geschreven
Cal Poly, Team 1-13, Amido Winter 2011 Lid van Cal Poly, Team 1-13, Amido Winter 2011
CPSU-AMIDO-W11S1G13
5 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 24
Altijd: 3,998
