Ga door naar hoofdinhoud
Pentax Optio WG-3 GPS Lens Assembly Replacement
Wat je nodig hebt
  1. Pentax Optio WG-3 GPS Lens Assembly  Replacement, Lens Assembly: stap 1, afbeelding 1 van 1
    • Turn over the camera so the screen is facing up.
    • Remove the four 5 mm Phillips #000 screws that secure the outer cover.
  2. Pentax Optio WG-3 GPS Lens Assembly  Replacement: stap 2, afbeelding 1 van 1
    • Flip over the camera so the bottom is facing up.
    • Remove the single Phillips #000 screw.
    • Remove the cover.
  3. Pentax Optio WG-3 GPS Lens Assembly  Replacement: stap 3, afbeelding 1 van 1
    • Remove the eight 5 mm Phillips #000 screws holding the circuitry together.
  4. Pentax Optio WG-3 GPS Lens Assembly  Replacement: stap 4, afbeelding 1 van 1
    • Carefully remove the circuitry.
  5. Pentax Optio WG-3 GPS Lens Assembly  Replacement: stap 5, afbeelding 1 van 1
    • Flip the circuitry so that the lens is facing up and the flash component is on your right.
    • Identify the orange ribbon tape surrounding the lens.
  6. Pentax Optio WG-3 GPS Lens Assembly  Replacement: stap 6, afbeelding 1 van 1
    • There are three 5 mm Phillips #000 screws to be removed on the right side of the lens.
  7. Pentax Optio WG-3 GPS Lens Assembly  Replacement: stap 7, afbeelding 1 van 1
    • Gently slide the lens piece to the right, remove the tape and take it out.
Conclusie
Garrett Rose
373 Reputatie
2 handleidingen geschreven
IUPUI, Team 3-1, Harley Spring 2022 Lid van IUPUI, Team 3-1, Harley Spring 2022
IUPUI-HARLEY-S22S3G1
3 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 17
Altijd: 195
