Inleiding
Use this guide to replace the buttons on the back of the camera that control the various menu options.
Wat je nodig hebt
Stap 1 Back Case
Voorzichtig: stappen 1-6 komen van een handleiding die in bewerking is.
Remove all four 1 mm JIS #00 screws from the back of the camera.
Remove the eight JS#000 screws using a screwdriver and lift panel up.
This screw does not need to be removed.
Bijna klaar!
Conclusie
