Ga door naar hoofdinhoud
Pentax Optio WG-2 Battery Compartment Door Replacement
Wat je nodig hebt
  1. Voorzichtig: stappen 1-6 komen van een handleiding die in bewerking is.
    Pentax Optio WG-2 Battery Compartment Door Replacement, Back Case: stap 1, afbeelding 1 van 2 Pentax Optio WG-2 Battery Compartment Door Replacement, Back Case: stap 1, afbeelding 2 van 2
    • Remove all four 1 mm JIS #00 screws from the back of the camera.
  2. Pentax Optio WG-2 Battery Compartment Door Replacement: stap 2, afbeelding 1 van 1
    • Use your finger to peel the grip off the top of the camera.
    • For best results, start from the right side of the camera, opposite the buttons.
    • Once the grip is removed, you will most likely lose the water-tight seal.
  3. Pentax Optio WG-2 Battery Compartment Door Replacement: stap 3, afbeelding 1 van 1
    • Use the tweezers to remove the two buttons from the top of the camera.
    • The buttons may fall out while removing the grip.
  4. Pentax Optio WG-2 Battery Compartment Door Replacement: stap 4, afbeelding 1 van 3 Pentax Optio WG-2 Battery Compartment Door Replacement: stap 4, afbeelding 2 van 3 Pentax Optio WG-2 Battery Compartment Door Replacement: stap 4, afbeelding 3 van 3
    • Remove the three 1 mm JIS #000 screws from the top.
    • Remove the 1 mm JIS #000 screw from the bottom.
  5. Pentax Optio WG-2 Battery Compartment Door Replacement: stap 5, afbeelding 1 van 1
    • Carefully separate the back and the front of the camera.
    • There are three ribbon cables connecting the two boards. Be careful not to tear them.
  6. Pentax Optio WG-2 Battery Compartment Door Replacement: stap 6, afbeelding 1 van 1
    • Use the tip of a spudger to flip up the small retaining flaps on the ribbon cable ZIF connectors.
    • Carefully pull the ribbon cables out of their sockets.
  7. Pentax Optio WG-2 Battery Compartment Door Replacement, Battery Compartment Door: stap 7, afbeelding 1 van 3 Pentax Optio WG-2 Battery Compartment Door Replacement, Battery Compartment Door: stap 7, afbeelding 2 van 3 Pentax Optio WG-2 Battery Compartment Door Replacement, Battery Compartment Door: stap 7, afbeelding 3 van 3
    • Lift the cover as you normally would if replacing battery.
    • Holding the camera with the lens facing away from you and the battery slot upward slide the cover towards the back of the camera.
    • There is a pin (3/4 of an inch long) that attaches the cover to the camera and it will come loose when the cover is removed.
Conclusie
Matthew Bessette
658 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 6-7, Bhusal Spring 2016 Lid van UMass Dartmouth, Team 6-7, Bhusal Spring 2016
UMASSD-BHUSAL-S16S6G7
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 10
Altijd: 757
