Ga door naar hoofdinhoud
Pentax Optio S4i Front and Back Cover Replacement
Wat je nodig hebt
  1. Pentax Optio S4i Front and Back Cover Replacement, Front and Back Cover: stap 1, afbeelding 1 van 2 Pentax Optio S4i Front and Back Cover Replacement, Front and Back Cover: stap 1, afbeelding 2 van 2
    • Remove the following screws:
    • Two silver 3.15mm Phillips #00 screws on the right side of the camera
    • Two silver 2.08mm Phillips #00 screws on the left side of the camera
  2. Pentax Optio S4i Front and Back Cover Replacement: stap 2, afbeelding 1 van 1
    • Remove the two indicated screws on the bottom of the camera:
    • The screw circled in red is a longer silver 3.15mm Phillips #00 screw
    • The screw circled in blue is a shorter silver 2.25mm Phillips #00 screw
  3. Pentax Optio S4i Front and Back Cover Replacement: stap 3, afbeelding 1 van 2 Pentax Optio S4i Front and Back Cover Replacement: stap 3, afbeelding 2 van 2
    • Carefully pull the back of casing away from the front.
  4. Pentax Optio S4i Front and Back Cover Replacement: stap 4, afbeelding 1 van 3 Pentax Optio S4i Front and Back Cover Replacement: stap 4, afbeelding 2 van 3 Pentax Optio S4i Front and Back Cover Replacement: stap 4, afbeelding 3 van 3
    • After removing the back cover, several things must be removed.
    • Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
  5. Pentax Optio S4i Front and Back Cover Replacement: stap 5, afbeelding 1 van 2 Pentax Optio S4i Front and Back Cover Replacement: stap 5, afbeelding 2 van 2
    • To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nicole Wong
329 Reputatie
3 handleidingen geschreven
Cal Poly, Team 4-29, Regan Winter 2011 Lid van Cal Poly, Team 4-29, Regan Winter 2011
CPSU-REGAN-W11S4G29
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 3,225
