Ga door naar hoofdinhoud
Penguin FZ-8 28” Tower Fan Blade Replacement
Wat je nodig hebt
  1. Penguin FZ-8 28” Tower Fan Blade Replacement, Fan Blade: stap 1, afbeelding 1 van 1
    • Flip the fan onto its side so that you can access the base of the fan.
    • Remove the single 11 mm screw using a Phillips #1 screwdriver.
  2. Penguin FZ-8 28” Tower Fan Blade Replacement: stap 2, afbeelding 1 van 3 Penguin FZ-8 28” Tower Fan Blade Replacement: stap 2, afbeelding 2 van 3 Penguin FZ-8 28” Tower Fan Blade Replacement: stap 2, afbeelding 3 van 3
    • Rotate the base of the fan counter-clockwise to detach it from the rest of the fan. The base can be separated into two parts.
  3. Penguin FZ-8 28” Tower Fan Blade Replacement: stap 3, afbeelding 1 van 2 Penguin FZ-8 28” Tower Fan Blade Replacement: stap 3, afbeelding 2 van 2
    • Remove four 5 mm screws from the sides of the base of the fan using the Phillips #1 screwdriver.
  4. Penguin FZ-8 28” Tower Fan Blade Replacement: stap 4, afbeelding 1 van 2 Penguin FZ-8 28” Tower Fan Blade Replacement: stap 4, afbeelding 2 van 2
    • Remove the two 5 mm screws located on the outside of the case inside the holes using the Phillips #1 screwdriver.
  5. Penguin FZ-8 28” Tower Fan Blade Replacement: stap 5, afbeelding 1 van 2 Penguin FZ-8 28” Tower Fan Blade Replacement: stap 5, afbeelding 2 van 2
    • Remove a single 5 mm screw on the outside cover of the fan using the Phillips #1 screwdriver.
    • Gently lift the top cover of the fan halfway to expose the single 5 mm screw. Remove this screw using the same Phillips #1 screwdriver.
  6. Penguin FZ-8 28” Tower Fan Blade Replacement: stap 6, afbeelding 1 van 2 Penguin FZ-8 28” Tower Fan Blade Replacement: stap 6, afbeelding 2 van 2
    • Pinch the sides of the case to remove the case from the rest of the fan.
  7. Penguin FZ-8 28” Tower Fan Blade Replacement: stap 7, afbeelding 1 van 1
    • Remove the single 5 mm screw between the fan blade and the motor using the Phillips #1 screwdriver.
  8. Penguin FZ-8 28” Tower Fan Blade Replacement: stap 8, afbeelding 1 van 2 Penguin FZ-8 28” Tower Fan Blade Replacement: stap 8, afbeelding 2 van 2
    • Remove the two 5 mm screws holding the fan blade in place using the Phillips #1 screwdriver.
  9. Penguin FZ-8 28” Tower Fan Blade Replacement: stap 9, afbeelding 1 van 1
    • Remove the fan blade from the device and clean it off before reassembling your device.
Conclusie
Ethan
169 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 12
Altijd: 1,178
