Ga door naar hoofdinhoud
Pebble Time Screen Replacement
Wat je nodig hebt
  1. Pebble Time Screen Replacement, Screen Cover: stap 1, afbeelding 1 van 1
    • Lay the watch flat on your workstation.
  2. Pebble Time Screen Replacement: stap 2, afbeelding 1 van 2 Pebble Time Screen Replacement: stap 2, afbeelding 2 van 2
    • Use the metal spudger to carefully pull apart the screen cover from the case.
    • Replace the metal spudger with a plastic opening tool to hold the cover open.
  3. Pebble Time Screen Replacement: stap 3, afbeelding 1 van 1
    • Use the metal spudger tool to carefully loosen the rest of the cover.
  4. Pebble Time Screen Replacement: stap 4, afbeelding 1 van 1
    • Carefully, pull apart the cover with the plastic opening tool.
  5. Pebble Time Screen Replacement, Screen: stap 5, afbeelding 1 van 1
    • Insert metal spudger into the side of the screen shown in the picture.
  6. Pebble Time Screen Replacement: stap 6, afbeelding 1 van 1
    • Use the metal spudger to pry the screen up.
  7. Pebble Time Screen Replacement: stap 7, afbeelding 1 van 3 Pebble Time Screen Replacement: stap 7, afbeelding 2 van 3 Pebble Time Screen Replacement: stap 7, afbeelding 3 van 3
    • Once screen is lifted, insert plastic opening tool between the screen connector and circuit board.
    • Disconnect the screen from the circuit board.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Saud Al-Malki
110 Reputatie
1 Handleiding geschreven
USF Tampa, Team 1-3, Sullivan Spring 2017 Lid van USF Tampa, Team 1-3, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G3
4 Leden
10 handleidingen geschreven
3Gids Commentaar
Where can I buy the display replacement?
ulises - Antwoord
Hello Ulises,
Based off of my search, I couldn’t find any place where you can buy a display replacement. I advise you to look on Ebay, Amazon, or you can contact Pebble Time for more information at https://www.pebble.com or +18882245820. If none of this works out for you, you might want to check local tech repair shops.
Hope this helps.
Saud Al-Malki - Antwoord
Hola.
¿I have a question ?
What adhesive What adhesive should I buy to stick it again after placing the screen?
bladimir gonzalez matos - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 41
Altijd: 3,748
