Ga door naar hoofdinhoud
Pebble Time Round Glass Screen Protector Replacement
Wat je nodig hebt
  1. Pebble Time Round Glass Screen Protector Replacement, Glass Screen Protector: stap 1, afbeelding 1 van 1
    • Wedge an opening tool between the case of the watch, and the glass screen bezel.
    • Pry the screen bezel away from the device.
    • If you have a difficult time getting the front bezel to separate from the case, try warming the watch up with a hair dryer.
    • There are three very tiny springs that are compressed between holes in the case and the front bezel. They can pop out once the bezel is removed, so don't lose them! Remove them and put them somewhere safe once the bezel is removed.
  2. Pebble Time Round Glass Screen Protector Replacement: stap 2, afbeelding 1 van 1
    • Pull the screen protector away from the device, breaking glue sealant.
    • Separate the screen protector from the screen.
    • To re-seal the glass protector's glue, simply heat the glue.
Conclusie
Kyle
85 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 4-5, Gulbrandsen Fall 2021 Lid van UMass Dartmouth, Team 4-5, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G5
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 292
