Ga door naar hoofdinhoud
Pebble Time Circuit Board Replacement
Wat je nodig hebt
  1. Pebble Time Circuit Board Replacement, Screen Cover: stap 1, afbeelding 1 van 1
    • Lay the watch flat on your workstation.
  2. Pebble Time Circuit Board Replacement: stap 2, afbeelding 1 van 2 Pebble Time Circuit Board Replacement: stap 2, afbeelding 2 van 2
    • Use the metal spudger to carefully pull apart the screen cover from the case.
    • Replace the metal spudger with a plastic opening tool to hold the cover open.
  3. Pebble Time Circuit Board Replacement: stap 3, afbeelding 1 van 1
    • Use the metal spudger tool to carefully loosen the rest of the cover.
  4. Pebble Time Circuit Board Replacement: stap 4, afbeelding 1 van 1
    • Carefully, pull apart the cover with the plastic opening tool.
  5. Pebble Time Circuit Board Replacement, Screen: stap 5, afbeelding 1 van 1
    • Insert metal spudger into the side of the screen shown in the picture.
  6. Pebble Time Circuit Board Replacement: stap 6, afbeelding 1 van 1
    • Use the metal spudger to pry the screen up.
  7. Pebble Time Circuit Board Replacement: stap 7, afbeelding 1 van 3 Pebble Time Circuit Board Replacement: stap 7, afbeelding 2 van 3 Pebble Time Circuit Board Replacement: stap 7, afbeelding 3 van 3
    • Once screen is lifted, insert plastic opening tool between the screen connector and circuit board.
    • Disconnect the screen from the circuit board.
  8. Pebble Time Circuit Board Replacement, Circuit Board: stap 8, afbeelding 1 van 1
    • Keep the watch flat on your workstation.
  9. Pebble Time Circuit Board Replacement: stap 9, afbeelding 1 van 1
    • Locate the three screws on the circuit board.
    • Remove using the J000 Philips head screwdriver.
  10. Pebble Time Circuit Board Replacement: stap 10, afbeelding 1 van 3 Pebble Time Circuit Board Replacement: stap 10, afbeelding 2 van 3 Pebble Time Circuit Board Replacement: stap 10, afbeelding 3 van 3
    • Carefully disconnect the connector wire on the bottom left edge of the circuit board using a plastic opener tool.
    • Move apart the connector to expose the fourth screw.
  11. Pebble Time Circuit Board Replacement: stap 11, afbeelding 1 van 1
    • Remove the final screw from the circuit board with a J000 Philips head screwdriver.
  12. Pebble Time Circuit Board Replacement: stap 12, afbeelding 1 van 2 Pebble Time Circuit Board Replacement: stap 12, afbeelding 2 van 2
    • Turn the watch to the side and use the plastic opening tool to lift up the circuit board.
    • Remove the circuit board from the case.
Conclusie
Nicolas Hempe
1.468 Reputatie
5 handleidingen geschreven
USF Tampa, Team 1-3, Sullivan Spring 2017 Lid van USF Tampa, Team 1-3, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G3
4 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 1,010
