Inleiding
Would you like to switch out the watch band on your Pebble Steel from leather to metal or vice versa? This guide will show you how.
Wat je nodig hebt
Gereedschap gebruikt in deze stap:Flathead 1.5 mm Screwdriver$5.49
Place the watch on its side to expose the side pins.
Use a 1.5 mm flathead screwdriver to unscrew the pin that is holding the band.
Één opmerking
One of my Pebble Steel pins comes out just as expected, but the other just spins, and doesn’t come out. Any ideas?
