Ga door naar hoofdinhoud
Patching a Bicycle Tire Inner Tube
Wat je nodig hebt
  1. Patching a Bicycle Tire Inner Tube, Rear Wheel: stap 1, afbeelding 1 van 2 Patching a Bicycle Tire Inner Tube, Rear Wheel: stap 1, afbeelding 2 van 2
    • Flip the quick release lever on the wheel.
  2. Patching a Bicycle Tire Inner Tube: stap 2, afbeelding 1 van 1
    • Squeeze the brake arms together and lift the brake cable from the caliper arms.
  3. Patching a Bicycle Tire Inner Tube: stap 3, afbeelding 1 van 1
    • Hold the wheel to the ground, and pull the bike frame up and away to remove the wheel from the bike.
  4. Patching a Bicycle Tire Inner Tube, Inner Tube: stap 4, afbeelding 1 van 1
    • Press the valve core while applying pressure to the tire to deflate the tire.
  5. Patching a Bicycle Tire Inner Tube: stap 5, afbeelding 1 van 2 Patching a Bicycle Tire Inner Tube: stap 5, afbeelding 2 van 2
    • Insert the flat part of a tire lever under the tire coping. Apply pressure to the other end of the lever to lift the tire up and out of the wheel.
    • Slide the lever around the circumference of the wheel to completely remove the tire.
    • Alternatively, if you have multiple tire levers, see if you can clip the first lever to a spoke to keep it in place. Then insert the second lever a few inches away. Clip it to a spoke. Insert the third lever a few more inches along. Take out the second lever and insert it it a few inches past the third. Work along the rim until the tire pops off.
  6. Patching a Bicycle Tire Inner Tube: stap 6, afbeelding 1 van 1
    • Remove the tube by pushing the valve through the hole in the rim and pulling the tube out from under the tire.
  7. Patching a Bicycle Tire Inner Tube, Patching a Bicycle Tire Inner Tube: stap 7, afbeelding 1 van 1
  8. Patching a Bicycle Tire Inner Tube: stap 8, afbeelding 1 van 2 Patching a Bicycle Tire Inner Tube: stap 8, afbeelding 2 van 2
  9. Patching a Bicycle Tire Inner Tube: stap 9, afbeelding 1 van 1
    • Remove the tube by pushing the valve through the hole in the rim and pulling out completely.
  10. Patching a Bicycle Tire Inner Tube: stap 10, afbeelding 1 van 2 Patching a Bicycle Tire Inner Tube: stap 10, afbeelding 2 van 2
    • Locate the leak by first over inflating the tire.
    • Place the tire under water and look for bubbles to find the leak.
  11. Patching a Bicycle Tire Inner Tube: stap 11, afbeelding 1 van 1
    • Mark the hole with a marker, and completely deflate the tire.
  12. Patching a Bicycle Tire Inner Tube: stap 12, afbeelding 1 van 1
    • Select a patch kit that you will use to patch the hole. Try to pick a patch that is appropriate for the size of the hole.
  13. Patching a Bicycle Tire Inner Tube: stap 13, afbeelding 1 van 1
    • Clean the area near the hole with soap and water, then dry it thoroughly.
    • Rough up the area around the hole with an abrasive surface such as sand paper until the area around the leak loses its shine.
  14. Patching a Bicycle Tire Inner Tube: stap 14, afbeelding 1 van 1
    • Apply rubber cement to an area around the hole that is bigger than the patch to ensure that the patch bonds completely.
  15. Patching a Bicycle Tire Inner Tube: stap 15, afbeelding 1 van 1
    • Apply the patch to the area.
  16. Patching a Bicycle Tire Inner Tube: stap 16, afbeelding 1 van 1
    • Apply pressure to the patch until the rubber cement is dry.
Conclusie
To reassemble your wheel, follow these instructions in reverse order starting at step three.
6 andere personen hebben deze handleiding voltooid.
Travis Tonder
3.175 Reputatie
4 handleidingen geschreven
Cal Poly, Team 5-13, Maness Fall 2010 Lid van Cal Poly, Team 5-13, Maness Fall 2010
CPSU-MANESS-F10S5G13
4 Leden
17 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 12
Altijd: 4,137
