Inleiding
So a ding is basically any noticeable blemish in the board's fiberglass covering. It usually manifests itself as a cracked windshield like fracture. It could be long and skinny (like my rail dings, typically) or short and wide (if you hit a strategically placed jagged rock). You may also not think you have a ding at all, or anything worrying about, then you start noticing a slight yellow discoloration in a certain area-well, odds are you are letting in a little water in that area. Which affects how your board floats and even maneuvers.
Wat je nodig hebt
So, to begin, we need a nice clean working area. My place is small so I used my patio set (not the best idea though, as my wife flipped when she found out I was using toxic chemicals where we occasionally eat, just beware.)
Things you will need:
Surfboard with dings
Cleaning tools: wax comb, rag, and Gloves!!!
Resin, Q-Cell Filler, Hardener, Fiberglass Cloth
Mixing cup, stirring stick,Transparency
Sand paper: 1 rough grit and 1 fine grit
Starbucks (optional)
Now we need to clean the dinged area of all the wax and fiberglass flakes.
Grab your comb and scrape any wax from around the area to be repaired.
Sand down, approximately 1/4", till you have a nice smooth surface.
Cut a small groove (in the direction of the ding) to give the repair mixture somewhere to seep into.
Now we come to the mixing process.
First figure how much resin you are going to need to adequately cover the cloth piece with a little to spare to pre-dab the dinged area.
Add Filler, it helps to make the solution less watery and more workable
Then add the hardener; you only need a little and it really depends on the temp. Your box should say what is appropriate for your particular weather.
Application Process:
Pre-dab the area with some of the solution, if there is a chunk of the fiberglass gone, use the solution generously to fill void.
Spread the soaked fiberglass cloth over the dinged area and smooth it out with your fingers.
Use the transparency to spread the cloth evenly, working out any noticeable bubbles.
Curing and Finishup:
Let the mixture cure.
It should take, depending on your weather, about 1 hour or so to dry completely.
Don't remove the transparency until dry.
Once dry, remove the transparency and use a fine sand paper to even out any new bumps from the new fiberglass surface.
Then, voila! your board should be back to working order. Get out there and this time try to be more careful on the trip back to the car. ;)
3 andere personen hebben deze handleiding voltooid.
