Ga door naar hoofdinhoud
Patch your Patagonia Nano Puff ® Jacket with Repair Tape
Wat je nodig hebt
  1. Patch your Patagonia Nano Puff ® Jacket with Repair Tape, Patch your Patagonia Nano Puff ® Jacket with Repair Tape: stap 1, afbeelding 1 van 1
    • Inspect the damage on your jacket. Clip any dangling threads or fabric using small scissors.
  2. Patch your Patagonia Nano Puff ® Jacket with Repair Tape: stap 2, afbeelding 1 van 3 Patch your Patagonia Nano Puff ® Jacket with Repair Tape: stap 2, afbeelding 2 van 3 Patch your Patagonia Nano Puff ® Jacket with Repair Tape: stap 2, afbeelding 3 van 3
    • Grab your repair tape.
    • Flip the repair tape to the back side.
    • Using a permanent marker, draw an oval slightly larger than the hole.
    • If you have a wide hole, you can use a rectangle, but be sure to round the edges. Rounding the edges prevents the corners from getting caught and peeling up.
  3. Patch your Patagonia Nano Puff ® Jacket with Repair Tape: stap 3, afbeelding 1 van 2 Patch your Patagonia Nano Puff ® Jacket with Repair Tape: stap 3, afbeelding 2 van 2
    • Cut out your shape using scissors.
  4. Patch your Patagonia Nano Puff ® Jacket with Repair Tape: stap 4, afbeelding 1 van 3 Patch your Patagonia Nano Puff ® Jacket with Repair Tape: stap 4, afbeelding 2 van 3 Patch your Patagonia Nano Puff ® Jacket with Repair Tape: stap 4, afbeelding 3 van 3
    • Using your fingernail, or a pin, peel the backing off the tenacious tape, so that you only have the clear sticky layer.
    • Be sure not to touch the sticky side of the tape as this will gum up the tape and it won’t stick well.
  5. Patch your Patagonia Nano Puff ® Jacket with Repair Tape: stap 5, afbeelding 1 van 2 Patch your Patagonia Nano Puff ® Jacket with Repair Tape: stap 5, afbeelding 2 van 2
    • Lay the tape over the hole and press the tape down with your finger.
  6. Patch your Patagonia Nano Puff ® Jacket with Repair Tape: stap 6, afbeelding 1 van 2 Patch your Patagonia Nano Puff ® Jacket with Repair Tape: stap 6, afbeelding 2 van 2
    • Use a fingernail or spudger to work out all of the air bubbles under the tape. Continue rubbing the tape until it is well-adhered.
Eindstreep
9 andere personen hebben deze handleiding voltooid.
Brittany McCrigler
89.014 Reputatie
131 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.817 handleidingen geschreven
2 opmerkingen
I followed this tutorial and used Tenacious tape by Gear Aid because it claims to not leave a residue behind if removed. That was a bad idea. I am now ready to upgrade this patch to a sewn one and removing the tape is absolutely leaving behind a residue. Really annoyed right now.
Ling Wang - Antwoord
This is really helpful, thanks.
James
James Riley - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 25
Afgelopen 30 dagen: 156
Altijd: 45,303
