Ga door naar hoofdinhoud
Parrot FLYPAD Joystick Replacement
Wat je nodig hebt
  1. Parrot FLYPAD Joystick Replacement, Joystick: stap 1, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Magnetic Project Mat
    $19.95
    Koop
    • Total of 6 Screws are located in the back of the controller.
    • Four 0.9mm T6 screws
    • Two 0.1mm T6 screws
    • Flip the Flypad over.
    • Remove the six screws using a T6 screwdriver.
    • Use a Magnetic Mat to prevent loss of screws. Set aside.
  2. Parrot FLYPAD Joystick Replacement: stap 2, afbeelding 1 van 1
    • Flip the Flypad over again and separate the front and back. Be sure to remove the foam adhesive that connects the front plate to the motherboard.
    • Be aware that the Buttons (L1,R1) may fall out. Remember to put them back in place during reassembly.
    • Use Ph0 tool to remove the screws holding the motherboard in place.
    • Gently remove the motherboard from the front plate.
  3. Parrot FLYPAD Joystick Replacement: stap 3, afbeelding 1 van 2 Parrot FLYPAD Joystick Replacement: stap 3, afbeelding 2 van 2
    • Pop the joysticks out by pulling gently.
  4. Parrot FLYPAD Joystick Replacement: stap 4, afbeelding 1 van 1
    • Unscrew and replace joystick caps for a more comfortable grip.
Conclusie
HUY NGUYEN
376 Reputatie
3 handleidingen geschreven
UW Tacoma, Team S3-G5, Liner Spring 2017 Lid van UW Tacoma, Team S3-G5, Liner Spring 2017
UWT-LINER-S17S3G5
5 Leden
2 opmerkingen
Do you know where I can find replacement joystick caps like the one shown in Step 4, please?
cbeilstein - Antwoord
Same question as above regarding joystick caps please
Alex - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 707
