Ga door naar hoofdinhoud
Parrot FLYPAD Buttons Replacement
Wat je nodig hebt
  1. Parrot FLYPAD Buttons Replacement, Buttons: stap 1, afbeelding 1 van 2 Parrot FLYPAD Buttons Replacement, Buttons: stap 1, afbeelding 2 van 2
    • Position the controller so the back is facing up.
    • Use a T6 screwdriver to remove the six screws on the back of the controller: four 0.9 mm screws and two 0.1 mm screws.
  2. Parrot FLYPAD Buttons Replacement: stap 2, afbeelding 1 van 2 Parrot FLYPAD Buttons Replacement: stap 2, afbeelding 2 van 2
    • Remove the foam adhesive that connects the front plate to the motherboard
    • The buttons (L1,R1) may fall out. Set aside to replace during reassembly.
    • Use a Phillips #0 screwdriver to remove the two 0.7 mm screws.
    • Remove the motherboard from the front plate.
  3. Parrot FLYPAD Buttons Replacement: stap 3, afbeelding 1 van 3 Parrot FLYPAD Buttons Replacement: stap 3, afbeelding 2 van 3 Parrot FLYPAD Buttons Replacement: stap 3, afbeelding 3 van 3
    • Remove the buttons from the front plate of the fly pad and replace as needed.
    • Hold the front plate of the fly pad facing downwards to prevent buttons from falling out.
    • Make sure the text on buttons L1 and R1 correctly line up with L2 and R2 when reassembling the device.
Conclusie
HUY NGUYEN
376 Reputatie
3 handleidingen geschreven
UW Tacoma, Team S3-G5, Liner Spring 2017 Lid van UW Tacoma, Team S3-G5, Liner Spring 2017
UWT-LINER-S17S3G5
5 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 6
Altijd: 547
