Ga door naar hoofdinhoud
Parrot FLYPAD Battery Replacement
Wat je nodig hebt
  1. Parrot FLYPAD Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Use a T6 screwdriver to remove the six screws from the back of the controller: four 0.9 mm screws and two 0.1 mm screws.
  2. Parrot FLYPAD Battery Replacement: stap 2, afbeelding 1 van 1
    • Use a screwdriver to remove the two 0.7 mm screws from the battery cover.
  3. Parrot FLYPAD Battery Replacement: stap 3, afbeelding 1 van 1
    • Separate the plastic cover from battery.
    • Avoid damaging the wires and gently remove the battery from the motherboard.
  4. Parrot FLYPAD Battery Replacement: stap 4, afbeelding 1 van 1
    • Use fingers to gently detach the battery wires from the motherboard.
  5. Parrot FLYPAD Battery Replacement: stap 5, afbeelding 1 van 1
    • Gently attach the wire connection from the new battery to the motherboard. Avoid touching the motherboard directly.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
HUY NGUYEN
376 Reputatie
3 handleidingen geschreven
UW Tacoma, Team S3-G5, Liner Spring 2017 Lid van UW Tacoma, Team S3-G5, Liner Spring 2017
UWT-LINER-S17S3G5
5 Leden
3Gids Commentaar
Where did I get a new battery? Can’t find one.
Randy - Antwoord Deel
Sorry where do I get a new parrot flypad battery. From Randy
where do I get a battery for this repair?
Philip Pepin - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 15
Altijd: 1,251
