Ga door naar hoofdinhoud
Inleiding
Use this guide to replace, propellers, shafts, and gears on a Parrot AR.Drone 2.0.
AR.Drone 2.0 spare parts and mounting tools are available from several Parrot retailers.
Onderdelen
Geen onderdelen opgegeven.
Video overzicht
  1. Remove the foam body. Remove the foam body.
    • Remove the foam body.
  2. Disconnect the battery by pulling the two red wires apart. Remove the battery by releasing the battery retaining straps.
    • Disconnect the battery by pulling the two red wires apart.
    • Remove the battery by releasing the battery retaining straps.
  3. Remove the small retaining clip using a plastic opening tool.
    • Remove the small retaining clip using a plastic opening tool.
    • Be careful as these clips can fly off and can be difficult to find.
  4. The propeller, gear, and rod can be removed by simply lifting them off the motor. The propeller, gear, and rod can be removed by simply lifting them off the motor. The propeller, gear, and rod can be removed by simply lifting them off the motor.
    • The propeller, gear, and rod can be removed by simply lifting them off the motor.
Conclusie
4 andere personen hebben deze handleiding voltooid.
David Hoyt
3.915 Reputatie
43 handleidingen geschreven
Cal Poly, Team 25-89, Amido Spring 2010 Lid van Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Leden
52 handleidingen geschreven
Één commentaar
any idea how to change the little gear?
Dar BS - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 30
Altijd: 7,560
