Ga door naar hoofdinhoud
Pantech Matrix Speaker Replacement
Wat je nodig hebt
  1. Pantech Matrix Speaker Replacement, Phone Orientation: stap 1, afbeelding 1 van 1
    • Place phone with screen side facing toward you.
  2. Pantech Matrix Speaker Replacement, Phone Orientation: stap 2, afbeelding 1 van 1
    • Flip phone over so screen side is now facing down.
  3. Pantech Matrix Speaker Replacement, Remove Back Cover: stap 3, afbeelding 1 van 2 Pantech Matrix Speaker Replacement, Remove Back Cover: stap 3, afbeelding 2 van 2
    • Gently slide the backside phone cover off exposing the battery underneath.
  4. Pantech Matrix Speaker Replacement, Lift Battery: stap 4, afbeelding 1 van 1
    • Carefully lift the battery up from where the spudger is pointed.
  5. Pantech Matrix Speaker Replacement, Remove Battery: stap 5, afbeelding 1 van 1
    • Remove the battery from its dock.
  6. Pantech Matrix Speaker Replacement, Slide SIM Card Out: stap 6, afbeelding 1 van 3 Pantech Matrix Speaker Replacement, Slide SIM Card Out: stap 6, afbeelding 2 van 3 Pantech Matrix Speaker Replacement, Slide SIM Card Out: stap 6, afbeelding 3 van 3
    • Slide the SIM Card out of its dock.
  7. Pantech Matrix Speaker Replacement, Remove Phone Screws: stap 7, afbeelding 1 van 2 Pantech Matrix Speaker Replacement, Remove Phone Screws: stap 7, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the four 2mm Phillips #000 screws from each corner of the device.
  8. Pantech Matrix Speaker Replacement, Remove Phone Casing: stap 8, afbeelding 1 van 3 Pantech Matrix Speaker Replacement, Remove Phone Casing: stap 8, afbeelding 2 van 3 Pantech Matrix Speaker Replacement, Remove Phone Casing: stap 8, afbeelding 3 van 3
    • Rotate the phone so the base is facing you.
    • Use spudger to separate phone casing and inside as shown.
    • Remove the casing carefully and set aside the rest of the phone.
  9. Pantech Matrix Speaker Replacement, Remove Phone Speaker: stap 9, afbeelding 1 van 2 Pantech Matrix Speaker Replacement, Remove Phone Speaker: stap 9, afbeelding 2 van 2
    • Place the spudger in the notch on the side of the speaker as shown.
    • Use the spudger to gently pry the speaker loose from its dock.
    • Remove the speaker fully from the phone.
Conclusie
Zeel Patel
1.078 Reputatie
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 8
Altijd: 175
