Inleiding
The motherboard of the Pantech Matrix C740 functions as the control center for phone functioning; however, faulty functioning of the motherboard may cause the device to either not function properly or not function at all. Therefore, this guide serves as an aid in the replacement of the motherboard for the Pantech Matrix C740.
Wat je nodig hebt
Gently slide the backside phone cover off exposing the battery underneath.
Use a Phillips screwdriver to remove the four 2mm Phillips #000 screws from each corner of the device.
Rotate the phone so the base is facing you.
Use spudger to separate phone casing and inside as shown.
Remove the casing carefully and set aside.
Place phone with exposed motherboard facing you.
Use a Phillips screwdriver to remove the five 2mm Phillips #000 screws holding the camera in place.
Use spudger to gently pry the keypad away from the rest of the phone.
Grip the motherboard and gently pull to separate it from the rest of the phone.
Één andere persoon heeft deze handleiding voltooid.
