Ga door naar hoofdinhoud
Pantech CDM8975 Keyboard Replacement
Wat je nodig hebt
  1. Pantech CDM8975 Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Remove the battery.
    • Remove four Phillips screws.
  2. Pantech CDM8975 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Pry up the plastic layer with a plastic opening tool.
    • NOTE: Be careful that you do not separate the two plastic parts completely they are fragile and may break if pulled too hard.
  3. Pantech CDM8975 Keyboard Replacement, Remove Keyboard: stap 3, afbeelding 1 van 1
    • Slide out the keyboard carefully in between the two layers.
  4. Pantech CDM8975 Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Insert the new keyboard in between the two layers carefully.
  5. Pantech CDM8975 Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Check if the edges are perfectly aligned between the two plastic layers after you insert the keyboard.
  6. Pantech CDM8975 Keyboard Replacement: stap 6, afbeelding 1 van 1
    • Press the two plastic layers back together.
    • Reinsert the four screws and place the battery and cover back.
Conclusie
You now have a new keyboard.
Richard
116 Reputatie
1 Handleiding geschreven
Ohio State, Team 1-4, Meza Spring 2014 Lid van Ohio State, Team 1-4, Meza Spring 2014
OSU-MEZA-S14S1G4
4 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 245
